Input Lag issue dissapear on new account!
Posted: 07 Jun 2023, 22:28
If the pc is not configured well or not optimized ... or maybe broken or not working correctly due to bad electricity/emi then why just after creating a new account either on csgo steam or valorant (tested by me) the problem just dissapear and everything feels fluid and smooth again,
But after you main that account it will get the lag with time...
It's hard to believe... But you can try that and see the results.
The input lag issue is noticed mostly by good players/with good potential, either we are getting nerfed or we have some mysterious energy beside our good reaction time and aim etc... that ruins the devices and electronics??
Even the desync is not noticable at all on new accounts.
I hope that we'll discuss this with evidence and facts and without emotions
Also one other thing that i have noticed is the more you play the more lag you will get with time
the fps is also affected, on newer account you will get high fps than your usual account.
Sometimes just swapping accounts even if the accounts are both old can provide the same effect like creating a new one.
