XL2411Z (AMA setting)
Lucfer
Post by Lucfer » 10 Aug 2014, 13:16
Hi all,
what's the best setting for AMA: OFF - HIGH or PREMIUM?
Thx in advance
Re: XL2411Z (AMA setting)
Post by Chief Blur Buster » 10 Aug 2014, 14:12
Lucfer wrote:Hi all,
Thx in advance
Usually AMA High is the best setting, unless you enable Blur Reduction (e.g. LightBoost or BENQ Blur Reduction) then it automatically configures the AMA to optimal blur-reduction-optimized settings that you usually should leave alone.
FYI, some good information can be found in Blur Buster's LCD Overdrive Artifacts page.
Lucfer
Post by Lucfer » 11 Aug 2014, 06:53
Thx for the useful informations chief.
