N/A
InputLagger
Re: Updated MouseTester 1.4
Hi. Thanks for the update. This is bug in the old program version or "something" really interfere with PC? What do you think?
viewtopic.php?f=10&t=9304&p=73941#p73941
that like mobo issueInputLagger wrote: ↑02 Jul 2023, 17:27Hi. Thanks for the update. This is bug in the old program version or "something" really interfere with PC? What do you think?
mendiguera_
is this ok?
mouse: g pro x 1000hz
- 1.4-test.png (54.74 KiB) Viewed 9646 times
no, this is jitter.
try another usb port / check firmware update, etc.
that not normal
Its the logitech energy saving features, pretty much turns off the mouse in fixed intervals for a brief moment to conserve battery life, turning it off should fix the spikes, the variation of 20%+- is likely powersaving features on in bios and OS.
Its actually fine if the energy saving features are on.
mendiguera_
Ragerlis wrote: ↑04 Jul 2023, 06:29Its the logitech energy saving features, pretty much turns off the mouse in fixed intervals for a brief moment to conserve battery life, turning it off should fix the spikes, the variation of 20%+- is likely powersaving features on in bios and OS.
tried diff mouses and feels the same
- Logitech g pro x superlight 1000hz up and down moviments
- g-pro-1000hz-up-down.png (59.03 KiB) Viewed 9444 times
- Logitech g pro x superlight 125hz circular moviments
- g-pro-125hz.png (64.56 KiB) Viewed 9444 times
- Razer viper mini 100hz circular moviments
- viper_mini_100hz.png (63.24 KiB) Viewed 9444 times
Well, first step is turning off the basic, put windows on high performance powerplan, turn off mouse and bios power saving features.mendiguera_ wrote: ↑04 Jul 2023, 09:28Ragerlis wrote: ↑04 Jul 2023, 06:29Its the logitech energy saving features, pretty much turns off the mouse in fixed intervals for a brief moment to conserve battery life, turning it off should fix the spikes, the variation of 20%+- is likely powersaving features on in bios and OS.
And remember, constant fast circular mouse movements, anything beside that will cause jitter in the statistics.
If no improvements are seen, a good way to diagnostic drivers is logging in safe mode and try doing the mousetester again, if the graphs are fine, the problem resides in drivers, if not, its likely hardware.
And this graph is an ok graph IF your power saving features are on, its normal 20ish% variance in a non tweaked OS.
