Hey everyone,
Was looking into getting a monitor upgrade with focus on eliminating motion blur; and there are a lot of options out there!
Checked the best monitor list on BLurBusters; however was unable to really figure out which one is "the current best"!
Required specs:
Monitor size: 27"
Resolution: 2560x1440p
Minimum refreshrate: 240hz
Any inputs on this?
Thanks a lot
Currently the best 1440p/27"/240hz monitor on the market?
henrikkp
mfk233
Re: Currently the best 1440p/27"/240hz monitor on the market?
I had the same question for the longest time.
I recently purchased the LG Oled 1440p/27inch but found it too dim for my lacking.(I sit by a window wall)
And since I work for 8+ hours a day, and then probably play the same game for an hour or so, I got really worried about burn-in.
Especially since I'd need to run it at its max brightness most of the time.
I ended up returning it since it didn't make sense to me to spend $1,000 and then have to baby a monitor.
I do miss the motion clarity though.
I have now ordered the new Asus TUF 260hz 1440p monitor that was announced in the spring of this year:
https://www.amazon.com/ASUS-Gaming-1440P-Monitor-VG27AQML1A/dp/B0BZR7WHXK
It is still in transit and I will report back.
The reason I picked it is because it has ELMB and I found that on my current Gigabye M27q (170hz/1440p), I do find the BFI clears up the motion quite a bit. It would be tough for me to move to a monitor that had no BFI.
Hope my musings help, and since the Asus is still in the return period, I would love to hear your thoughts on my purchase or whether I could have done better for the budget of around $400.
Ozzuneoj
Wow, thank you for mentioning this monitor. This is the first I've heard of it, and there is almost no information out there about it yet.mfk233 wrote: ↑23 Aug 2023, 10:59I had the same question for the longest time.
https://www.amazon.com/ASUS-Gaming-1440 ... B0BZR7WHXK
Seems to be pretty close to what I'm looking for in this thread.
The two big questions I have:
Does it have a KSF phosphor backlight which causes red ghosting artifacts?
Is it RGB or BGR sub pixel layout?
... bonus questions: Are there any really irritating quirks or limitations?
cuhnkedri
This monitor is amazing, and I really appreciate you bringing it up. I've never heard of it before, and there's barely any data available about it at the moment.mfk233 wrote: ↑23 Aug 2023, 10:59I had the same question for the longest time.
https://www.amazon.com/ASUS-Gaming-1440 ... B0BZR7WHXKbasketball stars
This seems like it's getting near to the right direction in this topic.
My two primary concerns are as follows: (1) Does it use a KSF phosphor backlight, the presence of which is known to produce red ghosting artifacts? Which color space is used for the individual pixels—RGB or BGR?
