Hello
Recently I bought a used Benq Zowie XL2546k monitor, unfortunately the monitor was damaged (broken matrix) during transport, my question is - is such a monitor still worth anything, or is it only suitable for a landfill?
Damaged matrix Benq Zowie XL2546k
- IMG20230629193532.jpg (4.7 MiB) Viewed 1227 times
- IMG20230629193520.jpg (2.56 MiB) Viewed 1227 times
Re: Damaged matrix Benq Zowie XL2546k
Depends on how handy you are.
(A) When selling, the monitor can be be useful as parts.
(B) The panel might be replaceable by a standalone panel from Alibaba/Aliexpress.
These panels may be somewhat standardized in the sense that multiple manufacturers share many 240Hz panels. But might have Zowie customizations (due to DyAc). You'd have to find out which panel part it is (e.g. panellook) and get the right panel, and transplant BenQ/Zowie's motherboard (scaler/TCON) to it. I have heard of a small few doing this, but it takes a person who knows what they are doing.
But, for the inexperienced, it is a lot of work to replace the LCD on these panels, though. And easy to accidentally get an incompatible panel. In the past, replacement panels (if you find the correct one), was typically only several tens of dollars (under $100) but the chinese parts supply crisis pushed some of these parts way up in price, especially for niche panels that are no longer stockpiled in large quantities. Depends on how lucky you get!
It may be easiest, however, to attempt a sell on eBay -- broken esports monitors typically sell for a few tens of dollars for repairers who need them to repair other monitors, or attempt self-repair. It may be practical if you have the original shipping box, but shipping cost of a monitor will be fairly high ($100+ even for same country).
Sending it to a local electronics recycler (even when having to pay a fee, such as $5), is temptingly easier in this case, though.
![Image](https://blurbusters.com/wp-content/uploads/2024/01/BlurBustersCollectionBanner-750x80.png)
Why not complain to the deliverer? It's their responsibility. Unless you damaged it yourself during transportation somehow, you should file a complaint. Don't know where you live but here the carrier would absolutely be held responsible for the damage.
Main display (TV/PC monitor): LG G3 55G33LA (4K 120 Hz OLED evo)
Tested displays: LG C2 42C21LA (120 Hz OLED) • Dell S3222DGM (165 Hz VA) • ASUS VG259QM/VG279QM (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (Mineral Satin, fully loaded, size C)
