Some question about this superb monitor:
-first of all i noticed an horizontal line at the half of the screen during some gameplay at tf2. Upper part of the screen seems to be lighter than the other. Settings are vsync on in ATI control center, 120hz@120fps, MBR on with 0 crosstalk and 2.5/3 persistence. It's normal or a monitor fault? It's the problem related to vsync or too much persistence?
-Second question is: for perfect motion clarity i read that the best way is to activate vsync and having 120fps@120hz. Whats the best way for activate vsync? From ATI cc or from the application? Whats the best value for FPS_max 119,120 or 121?
-third: accidentally touched ama setting when MBR on. The screen begin to produce some artifacts then i switch MBR to off and no more problems. Hope this accident don't hurt some hardware stuff?!
Hope someone can share his knowledge/settings for team fortress 2.
Btw this monitor is awesome, tracking like a boss and get kicked for aimbot worth it.
THX in advance:)
XL2411Z - TF2 questions/settings
Re: XL2411Z - TF2 questions/settings
Does the line still happen when you turn off BR?Lucfer wrote:Some question about this superb monitor:
Which Vertical Total are you using?
Can you post a picture of this effect?
If your play is running capped out at 120fps in TF2 with no frame drops, you may want to use VSYNC ON combined with a fps_max 119 (or fps_max 119.5 or 119.8). You want fps_max to be ever slightly lower than refresh rate, since that greatly reduces the input lag of VSYNC ON during Source Engine games.Lucfer wrote:-Second question is: for perfect motion clarity i read that the best way is to activate vsync and having 120fps@120hz. Whats the best way for activate vsync? From ATI cc or from the application? Whats the best value for FPS_max 119,120 or 121?
That said, if minimum lag is more important than perfect motion clarity, you can try uncapping your framerate and use VSYNC OFF, and use a really high fps_max value such as fps_max 300 or fps_max 500 in order to minimize harmonic microstutters.
Try these:
VSYNC ON combined with fps_max 119.5
VSYNC OFF combined with fps_max 500
And see which 'feels' better for you. If your GPU performance is sufficient, you may actually get VSYNC OFF performance with near-perfect motion if you don't notice the tearing.
It doesn't hurt things. Simply toggling Blur Reduction fixes this right up.Lucfer wrote:-third: accidentally touched ama setting when MBR on. The screen begin to produce some artifacts then i switch MBR to off and no more problems. Hope this accident don't hurt some hardware stuff?!
Sounds like blur reduction is really helping your aiming!Lucfer wrote:Btw this monitor is awesome, tracking like a boss and get kicked for aimbot worth it.
Falkentyne
As Chief said, don't touch AMA, as BBR has its own AMA built in (unless you want to turn off AMA, which will just give you ghosting instead of inverse ghosting). A similar thing happens if you switch from lightboost mode to BBR instantly; lightboost's AMA is used which creates intense overdrive artifacts, but the artifacts may be different (and in some cases, might be preferred) than changing AMA or using premiumLucfer wrote:Some question about this superb monitor:
THX in advance:)
Lucfer
1.Cant try with BR off (holidays)Chief Blur Buster wrote:Does the line still happen when you turn off BR?Lucfer wrote:Some question about this superb monitor:
2.No VT trick
3.same as 1
THX for the info, hope that line is only a setting problem and not a monitor fault ( yes im paranoid with new hw :p)
Lucfer
Seems to be a tf2 graphic setting. Using 'chris' configs' for maximize fps i get the following:
.using 'max frames' config (all possible settings low) there are 2 horizontal line at the center of the screen during motion (no lines while stationary) (vsync on/off and BR on/off at 120hz and 144hz)
. using other configs (just some graphic setting mid etc...) no more lines
So i think those lines was a graphic setting problem, maybe an AMD driver problem or something like that...
