Intel 13 Gen Bios Setting Request
Hi, does anyone have a good guide/recommendations on Intel 13th gen (13900k/13700k) bios setting for low latency/optimization?
Thanks!
Thanks!
Re: Intel 13 Gen Bios Setting Request
I'm curious, what are your basic BIOS settings for 13th gen?
Static clock / Stock?
Speedstep / Speedshift settings? Obviously if using a static clock these will be auto disabled.
cstates settings?
ASPM PCIE settings?
I'm also assuming you're using some form of XMP.
im use msi z790.kokkatc wrote: ↑19 Jul 2023, 13:57I'm curious, what are your basic BIOS settings for 13th gen?
cstates settings?
ASPM PCIE settings?
im not sure about dynamic clock vs fixed clock because if you set multiplayer it be lock with both options, but if you use dynamic clock it enable EIST and Turboboost.
im prefer to disable HXCI hand-off, usb audio controller, ARGB controller, CSM enable, e-cores bios enable / disable in OS.
for ram im just enable xmp and dont care about ram oc. Default msi SA voltages.
Im disable all in cpu advanced settings exept 100mhz lock on.
sherifmagdy32
These the ones i use for my motherboard
CPU C States Support
Disabled
Enhanced Halt State(C1E)
Disabled
Display Hidden OC Item
Enabled
CPU Thermal Throttling
Disabled
Legacy IO Low Latency
Enabled
Energy Efficient P-state
Disabled
Peer Memory Write Enabled
Enabled
Native ASPM
Disabled
PCIE ASPM Support
Disabled
Above 4G Decoding
Enabled
C.A.M. (Clever Access Memory)
Enabled
Thermal Throttling Level
Manual
BCLK Spread Spectrum
Disabled
PCIe Spread Spectrum Clocking
Disabled
PCI Express Clock Gating
Disabled
PCH Cross Throttling
Disabled
USB 2.0 Controller Mode
HiSpeed
Suspend to RAM
Disabled
Enable
Disable
Native ASPM
Disable
Enable
what board?sherifmagdy32 wrote: ↑19 Jul 2023, 15:10These the ones i use for my motherboard
Disabled
Disabled
Enabled
Disabled
Enabled
Disabled
Enabled
Native ASPM
Disabled
PCIE ASPM Support
Disabled
Above 4G Decoding
Enabled
Enabled
Manual
Disabled
Disabled
Disabled
Disabled
HiSpeed
Suspend to RAM
Disabled
Enable
Disable
Native ASPM
Disable
Enable
sherifmagdy32
asrock B365M Phantom Gaming 4Slender wrote: ↑19 Jul 2023, 16:14what board?sherifmagdy32 wrote: ↑19 Jul 2023, 15:10These the ones i use for my motherboard
Disabled
Disabled
Enabled
Disabled
Enabled
Disabled
Enabled
Native ASPM
Disabled
PCIE ASPM Support
Disabled
Above 4G Decoding
Enabled
Enabled
Manual
Disabled
Disabled
Disabled
Disabled
HiSpeed
Suspend to RAM
Disabled
Enable
Disable
Native ASPM
Disable
Enable
also for the asrock Z790 LiveMixer
Sebichek45
its kind of out of topic but, can you also do one for a b550 amd mobo?
send picSebichek45 wrote: ↑21 Jul 2023, 03:33
Sebichek45
Slender wrote: ↑21 Jul 2023, 16:20send picSebichek45 wrote: ↑21 Jul 2023, 03:33
I have a 5600x
I also disabled xhci handoff and any unneeded ports/devices.
Enabled pbo and set curve optimizer to -20.
Disabled lclk dpm
enabled rebar and 4g
- IMG_2743.jpeg (2.52 MiB) Viewed 16522 times
- IMG_2742.jpeg (2.25 MiB) Viewed 16522 times
- IMG_2741.jpeg (2.81 MiB) Viewed 16522 times
