Is it normal for my monitor's OSD to say Freesync is off when g-sync is enabled?
tombox
Post by tombox » 12 Jul 2023, 17:55
On my Acer Predator x27u oled freesync premium monitor it says freesync premium is off, even though g-sync is enabled and I guess working properly, according to the G-sync pendulum demo. I say I guess because I'm able to tick the g-sync option in the demo when I turn everything on. When I turn off freesync premium on the monitor and disable gsync via nvidia control panel, it won't let me tick the g-sync box in the G-sync pendulum demo.
If g-sync is working properly, is it normal for my monitor to say freesync is off on its OSD?
Is there another verification process to check if g-sync is working properly with my freeysnc premium monitor?
edit: https://blurbusters.com/gsync/gsync101- ... -settings/
Often times I find the answer after asking the question, which I guess is part of the process. Well, after writing this thread, I searched and found that link above. That article showed me how to use the gsync indicator, which is under the display option.
tombox
Re: Is it normal for my monitor's OSD to say Freesync is off when g-sync is enabled?
Post by tombox » 13 Jul 2023, 16:59
Edit: https://imgur.com/a/Pj6tGkm
Acer online tech support wanted me to return it, but should I really if G-sync says it's working via software?
