GSYNC makes my game look pretty and smooth which is cool.
What's the difference with having GSYNC enabled with capping in game fps at refresh rate of monitor compared to having it uncapped with a lot more fps
GSYNC fps question
Re: GSYNC fps question
For those who haven't bought VRR (G-SYNC/FreeSync) monitors yet, just buy more framerate range than VRR range .
Capping is simply a lesser pick-poison for game frame rates that want to go far beyond Hz, which will create the latency-change and-stutter effects as GSYNC switches to VSYNC ON or VSYNC OFF and then back, as framerates tries to go above/below.
esports atheletes need to buy 360-540Hz monitors if they want to use VRR, to skip the capping compromise. Then they can play most esports games in VRR since most won't exceed the frame rates of those ultra high Hz monitors.
Now if you are casual gaming, like Cyberpunk 2077 or Witcher or other games, then capping is simply mostly a quality fix, since you can get sudden latency increases or sudden tearing/stutter appearaces whenever frame rates unexpectedly exit VRR range.
bunkin
cs goes well above 500 at times, if I play with gsync should I leave it uncapped or cap it at 501 where fps won't go above 500..what's the different with gsync on with fps staying at 500 in game or fluctuating higher at times?Chief Blur Buster wrote: ↑16 Jul 2023, 22:15For those who haven't bought VRR (G-SYNC/FreeSync) monitors yet, just buy more framerate range than VRR range .
Is oc to 500 ok on monitor since it's literally built in on monitor settings instead of default 480, more of a marketing scheme?
Worstylolzs
bunkin wrote: ↑17 Jul 2023, 10:20cs goes well above 500 at times, if I play with gsync should I leave it uncapped or cap it at 501 where fps won't go above 500..what's the different with gsync on with fps staying at 500 in game or fluctuating higher at times?Chief Blur Buster wrote: ↑16 Jul 2023, 22:15For those who haven't bought VRR (G-SYNC/FreeSync) monitors yet, just buy more framerate range than VRR range .
How chief said, you can't go over of your monitor max refresh rate or it will be cause latency issue and over your max refresh rate g-sync will not work, because it work only in your refresh rate range. For more information check
101 g-sync guide. https://blurbusters.com/gsync/gsync101- ... settings/2
Second question is for some single thread in my opinion you talk about model aw2524h, what have function to overclock to 500hz from 480hz. Idk how to answer, but how I said, for this question will be good have new thread.
