I owned the LG 27 OLED and each time I turned the display off it ran pixel refresh and stayed off automatically which is great.
Swapped to the Asus for the SDR brightness and timings. I ran this panel for an entire day and it didn't automatically suggest pixel refresh even with my reminder set to 4 hours. When I manually ran it the screen automatically turned back on when I walked away but I wanted to keep it off... Like I'm not going to sit there for 6 minutes and watch my monitor to a refresh just to turn it off when its done. The LG one again stayed off and popped up each time.
Similar experience or is something wrong? On the 104 firmware.
PG27AQDM not auto running or suggest pixel refresh
- hart
Re: PG27AQDM not auto running or suggest pixel refresh
supposedly it runs when you turn it off after 4 hours of use, it just doesn't say that is gonna run it like LG
Displays: Dell AW2725DF + LG 27GL850B + LG Dual-UP 28MQ780 PSU: Corsair HX850i Mobo: B650E-E CPU: 7800x3D Cooling: Arctic LiquidFreezer III 420 RAM: 32gb DDR 6000 CL28 GPU: Strix 4090 SSD: Samsung 990 PRO 4TB + WD SN850X 2TB Mice: G-wolves HSK pro 4K + Razer Naga V2 pro Keyboard: Wooting 80HE Sound: Topping DX7 Pro+ (using optical) / HifiMan Edition XS / Bose QuietComfort Ultra OS: W10 pro
