Ghosting increases on monitor after plugging in phone charger, why ?
Bobo
Post by Bobo » 11 Aug 2023, 08:12
Plugging in the Turbo charger for my phone, in my power strip, increases the ghosting on my monitor by quite a noticeable amount.
it happens every time that i do it.
what would the cause for this be ?
TN_fun
Re: Ghosting increases on monitor after plugging in phone charger, why ?
Post by TN_fun » 12 Aug 2023, 06:20
Can you record a video, for example, a UFO ghosting test?
F1zus
Post by F1zus » 12 Aug 2023, 07:17
Bobo wrote: ↑
11 Aug 2023, 08:12
Obviously, the charger creates interference, like any other impulse device. The power supply is rather weak and is not able to protect the monitor panel from interference from the outlet.
amorou
Post by amorou » 22 Aug 2023, 18:36
Bobo wrote: ↑
11 Aug 2023, 08:12
Its a smps and its noisy , so as your pc psu , led lightbulbs.
Also if you have dimmer switch in house , remove it.
Cyanide_
Post by Cyanide_ » 01 Oct 2023, 12:32
amorou wrote: ↑
22 Aug 2023, 18:36
Bobo wrote: ↑
11 Aug 2023, 08:12
It might sound dumb, but can one of these new fancy "dimmer switch LED chandeliers" be causing some input lag? These are coming with remote control too.
amorou
Post by amorou » 01 Oct 2023, 14:28
Iserverthefirelord wrote: ↑
01 Oct 2023, 12:32
amorou wrote: ↑
22 Aug 2023, 18:36
Bobo wrote: ↑
11 Aug 2023, 08:12
Not knowing is never dumb
Answer is , yes it can
Just saying: its the circut in the switch that connected to your home circut could cause bad stuff , not the lamb itself
For what it looks like: ( or google "dimmer light switch inside")
The issue people complaining will not be created by these dimmer switches , but it could improve your gaming/lag (did mine) , You gotta try to disambling it from circut/wall
If you know nothing about electricty , please research how to not get electrocuted (felt responsible to write that)
Cyanide_
Post by Cyanide_ » 02 Oct 2023, 05:37
amorou wrote: ↑
01 Oct 2023, 14:28
01 Oct 2023, 12:32
amorou wrote: ↑
22 Aug 2023, 18:36
Bobo wrote: ↑
11 Aug 2023, 08:12
Yeah thanks lol, I indeed know close to nothing when it comes to electricity so I'm not even touching that :D especially when it's not my apartment I'm living in. But that lamp is right above my PC so I thought maybe it's causing some interference, it's also "buggy" turning on and off sometimes by it's own, might call an electrician or smth. Also moving PC to other area far away from that lamp improved gaming a bit but that might be a placebo.
amorou
Post by amorou » 02 Oct 2023, 07:50
02 Oct 2023, 05:37
amorou wrote: ↑
01 Oct 2023, 14:28
01 Oct 2023, 12:32
amorou wrote: ↑
22 Aug 2023, 18:36
Well you could construct entire towns electricity system with 0 practice and good research
As I said switch's circut will cause the erratic stuff and not via air but via cables.
You can remove it from circut/wall and plug it later and no one will notice
But if you rich I recommend calling an electrican to remove it, so you can watch him. You never know who you are speaking online , its very easy but you can die (unlikely but possible) if you contact live wire.
