AOC 24G2Z (240hz IPS) questions
dg1
Post by dg1 » 02 Sep 2023, 21:16
1-Is "Low Input Lag" mode on or off here:
I dont even remember what set of options greys it out anymore, tried a lot of stuff today without success...
2-Whenever I turn on the HDR Mode, the monitor gets to the "default profile", it turns off whatever profile may be set at the "Game Settings" menu at the moment, and greys the profile selector out. For me to switch between a stored profile and the default one with HDR on, I need first to activate/deactivate HDR and then go to the Game Settings to set a profile. Are there a simpler way to do that? This monitor has the worst buttons I've ever used in a screen, its terrible to change settings on it. The wobbling of its support (not the original one) only makes it worse. Its a true pain for me to keep switching between my gaming and casual settings, and I do that a lot while Im using the pc.
Lastly:
Ive recorded this video comparing it with a Zowie 144hz TN panel and they kinda are in the "same frame" (recorded at 60fps [i know, i know]) but the benq one is always quite a bit "ahead" on the consolidation of that frame. we can see by the "frame bar" that they are at the same frame but the image in the benq is pretty much formed already while in the AOC the pixels are only starting to change its color. For the human eye its is like the image 1f behind and Id like to improve that if possible. Any specific hints for that model?
