Hello everyone,
I downloaded the Blur busters strobe utility tool for my XL2566K. I was silly enough not to make note oft the original calibration settings in the app. I'd like to basically revert my monitor back to its default values before using the app.
Note: I haven't used CRU or Toasty, just simply the Strobe Utility app.
Any help appreciated.
HELP factory reset Blur Busters Strobe Utility
Depo
Re: HELP factory reset Blur Busters Strobe Utility
Bump.
Anyone??
Moderators?
π«₯
Anyone??
Moderators?
π«₯
You have to factory reset via the monitor menus, to get the original strobe data.
Forum Rules wrote:ββ1. Rule #1: Be Nice. This is published forum rule #1. Even To Newbies & People You Disagree With!
ββ2. Please report rule violations If you see a post that violates forum rules, then report the post.
ββ3. ALWAYS respect indie testers here. See how indies are bootstrapping Blur Busters research!
Depo
Thanks Chief,
Just to confirm I don't need to reset anything using CRU either?
Not that I used CRU it's just I did a search and on here and the only info retrieved was someone saying you have to use the reset.exe from CRU as well?
If you want to remove the Large Vertical Totals (custom modes, custom refresh rates, etc), yes, you have to run ToastyX reset-all.exe too, in addition. This resets your Windows operating system to only use the original Plug-n-Play EDID's that the monitor is giving to your display.
Avexic
what settings did you end up using?
