Page 1 of 3
Headaches of the Asus PG27AQN from an Asus XG27AQMR owner
Posted: 17 Oct 2023, 21:32
by liquidshadowfox
Impressive backlight strobing performance no doubt. I find it funny that it performs better the lower the refresh 360 < 240 < 144 < 120 hz. The Gsync performance is nothing to write home about, I've been using the Asus XG27AQM and Asus XG27AQMR for a while (with and without elmb sync which is pretty bad when put side by side to ULMB 2). After updating my nvidia drivers, updating the firmware on the PG27AQN I've encountered many issues:
1. Random black screens (this seems to have been mitigated for me after the firmware update, I haven't had a black screen after doing the DDU song and dance and promptly installing newest nvidia drivers from scratch)
2. Setting up per game profiles for ULMB 2 gave me massive headaches (read below)
To give context, I am really lazy and don't want to fiddle around with going into nvida control panel, disabling Gsync, going into monitor OSD to enable ULMB 2 and then undo it all when I switch to a game I don't want ULMB 2.
I found out I can set my global profile in NVP to be Gsync and then have per game profiles where each game I do want to use ULMB 2 I set it to be so (suspiciously it sets "Preferred refresh rate" and "Vertical Sync" in bold to "highest available" and "use the 3D application setting" respectively so I change "Preferred refresh" to "Application controlled" so when I choose a different refresh for my ULMB 2 game it more consistently kicks on ULMB 2). For most games doing this doesn't do squat and ULMB 2 always fails to come on, HOWEVER if you change the exe of the game's executable to have "fullscreen optimizations" to disabled it actually works when you boot up the game (awesome) BUT Vsync setting from the 3D application fails to do anything (If you enable NCP vsync on it'll either fail to go into ULMB 2 or you'll get really bad frame pacing for some reason), it runs unlocked for the whole session (I got around this by using RTSS scan line sync and moving the tear line consistently to the bottom of the screen where the crosstalk is bad anyways). Problem is, after I do the ULMB 2 session and either end the game or alt tab out I see the light goes from green (ULMB 2) to red (Gsync active) which is good but when I try to run the pendulum test I don't get the "gsync" watermark on the top right. I've tried to visually see if there was any tearing but I couldn't (as long as the fps is below the max refresh but above the max refresh is hard to see tearing anyways! XD) so if someone could verify this that'd be great (I tried using the RTSS color line thing I use for scanline sync and didn't see any tears so I assume Gsync still works). Here's where it gets crazy! I run the smooth frog demo from aperture grille's website and guess what? IT FIXES GSYNC such that I get the watermark again that it's active! so I can only assume this is clearly a software issue and I've love to see what kinda of code from that smooth frog demo actually fixed Gsync, might be a good script to run everytime a ULMB 2 game is done to restore proper gsync.
After all this headache is said and done I do have to say ULMB 2 looks really good at 240 hz and below. At 360 hz it looks way better than ELMB sync but obviously you need a machine to consistently push out that kind of frame rate and some games don't really need 360 hz worth of input latency reduction.
Re: Headaches of the Asus PG27AQN from an Asus XG27AQMR owner
Posted: 17 Oct 2023, 22:40
by jorimt
liquidshadowfox wrote: ↑
17 Oct 2023, 21:32
It was probably caused by the Nvidia driver issue apparently solved in the latest driver version:
viewtopic.php?f=2&t=12420&p=98433#p98433
Posted: 17 Oct 2023, 23:23
by liquidshadowfox
I spoke too soon, was playing eternal returned and the screen blacked out on me twice. I clean reinstalled this latest driver twice and it's still happening. Someone on reddit mentioned that setting the scaling to happen on the GPU got rid of the issue (instead of scaling on the display) so I'll try that now and see if it happens again. I would really like to keep this monitor but if it's going to be this inconsistent I might have to return it :L
Posted: 18 Oct 2023, 09:08
by jorimt
17 Oct 2023, 23:23
What are your monitor, NVCP (including color format and bit depth), and in-game settings in the problem title(s)?
Posted: 18 Oct 2023, 09:44
by liquidshadowfox
Monitor side:
1. Color temp: 5000k
2. OD: normal
3. Game visual: Racing mode
4. Auto SDR Brightness: on
5. Variable Backlight: off
6. Display Color Space: Wide Gamut
7. DSC: on
Everything else on monitor was kept stock from factory reset
NVCP side:
3D Settings:
1. Vertical sync: use 3D application
2. Monitor technology: Gsync
Resolution:
1. Resolution: 2560 x 1440
2. Refresh: 360 hz
3. Color depth: 12 bit
4. Color format: RGB
5. Output dynamic range: full
I had "Perform scaling on display" and I'm currently testing "Perform scaling on GPU" currently, so far no black screens, will continue testing today.
Game side: Game = Eternal Return
Window: borderless windowed
Graphics: Ultra
Vertical Sync: Enabled
Posted: 18 Oct 2023, 10:59
by jorimt
18 Oct 2023, 09:44
This was causing it for me pre-driver update. I lowered it to 8-bit, and the random black flicker disappeared.
I have set it back to 12-bit, but haven't played any games long enough to determine if the driver fixed it or not. Will likely do so this weekend.
As for scaling, I have mine set to "No scaling" on "Display."
Posted: 18 Oct 2023, 11:09
by liquidshadowfox
So it turns out this monitor has a lot less bugs with DSC turned off, will do more testing today but it looks like I can enable ULMB 2 per game and it successfully switches back to Gsync when I am done playing as long as I play within resolutions that don't require DSC... would be disappointing considering it's capable of 360 hz but ULMB 2 works better at 240 than 360 hz imo. I'll disable the scaling to see if it black screens on 360 hz with DSC on later this weekend probably
Posted: 18 Oct 2023, 11:17
by jorimt
18 Oct 2023, 11:09
Yeah, I think most users that purchase a DSC-capable display are initially blindsided by its restrictions and quirks, but it's a necessary evil to reach the required max resolution + refresh rate of the more cutting-edge models due to current-gen DisplayPort and HDMI bandwidth limitations.
HDMI 2.1 and DisplayPort 2.0 will help on future models, but a handful of models that already use them still have DSC in some cases (4k, etc).
Anyway, for ULMB2 purposes, I don't see a downside of disabling DSC if you're using 240Hz anyway (as it doesn't need DSC).
Posted: 18 Oct 2023, 11:38
by liquidshadowfox
I'll keep testing but man I'd hate to give up the 360 hz for valorant... Hopefully they roll out a new driver that fixes these issues in the future.
Posted: 18 Oct 2023, 13:15
by liquidshadowfox
When I re-enable DSC I only get 360 hz and I can't access the lower refresh rates. Any way to restore this?
