Hello guys,
so Ive decided to order the DIY kit through a friend in US and I assume the power supply is not compatible to the european power plugs.
Is anyone here using the DIY kit in europe and what Power Supply are you guys using that is compatible in your country?
Thanks in advance.
Any europeans using DIY G-Sync kit for Asus VG248?
MrBrown
Falkentynes BenQ Service Menu thread: http://forums.blurbusters.com/viewtopic.php?f=2&t=2467
- fenderjaguar
Re: Any europeans using DIY G-Sync kit for Asus VG248?
The power supply it comes with can take 100v-240v. I'm in the UK and using it's fine.
MrBrown
Thanks for the answer mate, thats ofcourse really nice that I wont need a special psu.
One more quick question- at 144 hz, the Asus has pretty washed out colors that are really hard to calibrate, how are the colors with the Gsync kit installed at 144 hz? Are they worse or the same or maybe slightly better?
Thanks.
Thanks.
PoWn3d_0704
Its more or less the same. You arent going to get great colors. You just cant with the 6-bit TN panel at that kind of Hz.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
MrBrown
Thanks for your reply.
