Dell Announce New Alienware 27″ 1440p 360Hz and 32″ 4K 240Hz QD-OLED Gaming Monitors
tong
Post by tong » 23 Oct 2023, 13:13
The 360hz model will be very interesting because of OLED's sub 1ms pixel response time, so it wont ghost as bad as current the LCD offerings.
This model will probably make fast-IPS and TN panels obsolete once and for all, and if the tech remains progressing this fast then by 2025 I wouldnt be surprised if we see 500hz OLEDs.
Source: https://tftcentral.co.uk/news/dell-anno ... g-monitors
hart
Re: Dell Announce New Alienware 27″ 1440p 360Hz and 32″ 4K 240Hz QD-OLED Gaming Monitors
Post by hart » 28 Oct 2023, 01:58
tong wrote:
23 Oct 2023, 13:13
there are 480hz oled from LG already "announced" as tech not specific models for Q3/Q4 2024
Displays: Dell AW2725DF + LG 27GL850B + LG Dual-UP 28MQ780 PSU: Corsair HX850i Mobo: B650E-E CPU: 7800x3D Cooling: Arctic LiquidFreezer III 420 RAM: 32gb DDR 6000 CL28 GPU: Strix 4090 SSD: Samsung 990 PRO 4TB + WD SN850X 2TB Mice: G-wolves HSK pro 4K + Razer Naga V2 pro Keyboard: Wooting 80HE Sound: Topping DX7 Pro+ (using optical) / HifiMan Edition XS / Bose QuietComfort Ultra OS: W10 pro
doug5421
Post by doug5421 » 06 Nov 2023, 18:40
Surprised there isn’t more hype about these monitors on this forum.. What “real” advantages can we see from 360hz or even 480hz OLEDs vs 240hz? Anyone care to explain? At what point are enough frames “enough” on OLED? :D
Cuthalu
Post by Cuthalu » 07 Nov 2023, 09:20
doug5421 wrote:
06 Nov 2023, 18:40
Significantly less motion blur for starters. Check out Optimum Tech's review of the upcoming 540 Hz TN Asus - 240 Hz OLED is a blurry mess in comparison, and the Asus ain't perfect either. Obviously the higher Hz can also give smoother experience with slightly less input lag, but it's subjective how well you can spot the differences. It will be definitely interesting to see how close the 360 Hz QD-OLED can get in comparison to the new TN panel.
Jefa35
Post by Jefa35 » 14 Nov 2023, 07:27
Don't really understand the hype for this 360Hz OLED. New eTN 540Hz will be better motion clarity wise (even without BFI), will have less input lag (due to higher Hz), better visibility thanks to the higher brightness and LCD "greyish colors", and lastly better format (25" 1080p > 27" 1440p for comp games).
Brightness on OLED remains mediocre and insufficient, not even mentioning the risk of burn in, especially when playing FPS with the same HUD displayed for hours.
Of course for any other activities such as AAA solo games, movies etc OLED will be better, but such Hertz (360+) clearly aims toward competitive FPS games and for this usage there is just no reason to consider anything else than upcoming LCDs 540Hz.
PC: 3080 FE - 7800X3D / Monitor: VG259QM 280Hz / Mouse: Finalmouse UltralightX Guardian Medium / Keyboard: Wooting 60HE / Mousepads: Artisan Zero Soft, Hayate Otsu Soft, Raiden Mid, Hien Soft
tong
Post by tong » 20 Nov 2023, 11:00
Jefa35 wrote:
14 Nov 2023, 07:27
Turns out not everyone wants pure performance if it means garbage picture quality. Your last paragraph answers your own question.
Hitesh12
Post by Hitesh12 » 20 Nov 2023, 11:04
Jefa35 wrote:
14 Nov 2023, 07:27
"semi-competitive" games like battlefield, cod etc look great on oled and benefit a lot from high refresh rate
Even racing games look great on high refresh rate and on oled
I was gonna go for PG248QP but then I remembered I play these games as well. Now I'm gonna wait. Hopefully it's below AUD$2.5k
This is totally subjective. I would go for 27" 1440p over the other wherever possible
Depo
Post by Depo » 24 Nov 2023, 07:29
But what if you can't reach the 360hz in 1440p on the new Oleds won't they be a stuttering mess?
Jefa35
Post by Jefa35 » 29 Nov 2023, 04:55
tong wrote:
20 Nov 2023, 11:00
Jefa35 wrote:
14 Nov 2023, 07:27
When you play a competitive game all you want regarding the picture is great visibility, and OLED is mediocre in that aspect. If you are interested in a 360Hz display it means you plan to play and invest time into competitive games. Fur such usage OLED cannot be considered because of its visibility and risk of burn in (really high on a FPS game with the same HUD displayed for hours). So I don't really see for who OLED 360Hz are meant for.
