Motion blur reduction black screen [fixed]
soulhunter0504
Post by soulhunter0504 » 20 Aug 2014, 23:49
I have recently purchased a XL2411Z and I have just received it today. Everything went perfectly fine and I was enjoying toying with my monitor for the day.
It all started when I reset the settings to factory default, I toyed with a few things and all of the sudden the screen went completely black. I restarted my computer and everything worked from the bios to the login screen and it went black once again.
I fixed everything from then and dvi works again, I think there was an issue where when motion reduction is on it darkens the screen very heavily and then suddenly it is completely black like before. I can now run my new monitor without motion blur reduction but this is not what I want to do, I also want to use the strobe utility. Whenever I try to turn blur reduction on it gives me the same black screen, any way to fix this? I tried to use strobe utility without the reduction on because it doesn't work and the utility does not work as well anymore for me.
Thank you for your input.
Re: Motion blur reduction black screen
Post by Chief Blur Buster » 21 Aug 2014, 00:28
Try these:
- Switch to a different refresh rate before turning on blur reduction
- Adjust crosstalk to 0
- Now try the original refresh rate.
Does this work?
soulhunter0504
Post by soulhunter0504 » 21 Aug 2014, 00:45
Chief Blur Buster wrote:Try these:
Does this work?
Works like a charm! Thanks.
I have a different question if you would be so kind:
When I am on my desktop I check the system information and it tells me 1080p@60. Should it be 60hz at desktop and chromium?
I also play a certain game; Rust. When I check the system information it says @60 as well while in csgo it displays @120. Rust seems smoother than my old 60hz monitor and I was wondering if this is just a bug on the information while it runs at a perfect 120?
Post by Chief Blur Buster » 21 Aug 2014, 01:42
soulhunter0504 wrote:I also play a certain game; Rust. When I check the system information it says @60 as well while in csgo it displays @120. Rust seems smoother than my old 60hz monitor and I was wondering if this is just a bug on the information while it runs at a perfect 120?
The on-screen information on the monitor is flawed when running the VT1350 tweak.
