Electricity caused my PC to stutter for 3 years… I finally fixed it.
lavar
input laggers flooded the post. dm if u suffer the same issue and not input lag if u want more not replying to comments waste of time.
ahead
AyayronPlays
lavar
Re: Electricity caused my PC to stutter for 3 years… I finally fixed it.
Seeing your post history, you suffer from input lag issues.
If you read the bottom of my post, you would see that this has nothing to do w input lag and I asked this post to not be bombarded w posts regarding Input lag.
My fix does not help input laggers and they’ve tried it dozens of times. This is strictly for people who only suffer from stuttering. No matter what fixes they try or what time they play at the stuttering never changes. Once the PC connects to our outlets the stuttering happens instantly.
lavar
He has input lag issues. He clearly didn’t read the bottom of the post where I asked for this post not be bombarded w input laggers as they have a million threads… since this issue is not the same.. and only a few threads like mine exist.
AyayronPlays
Glad you managed to resolve your issues with stuttering. That must have been annoying to deal with. Interesting it took both to get it to a playable state.lavar wrote: ↑08 Nov 2023, 20:13He has input lag issues. He clearly didn’t read the bottom of the post where I asked for this post not be bombarded w input laggers as they have a million threads… since this issue is not the same.. and only a few threads like mine exist.
Everythingblows
Hi I am very interested in this.
lavar
It seems you have input lag issues. I can’t help you there bro, I wish I could. This issue is not that. I know tons of people who’ve spent years trying to fix it.. very capable people also…Everythingblows wrote: ↑08 Nov 2023, 22:31Hi I am very interested in this. My discord is Turd36 #1548 if you don’t mind exchanging a few messages
i wish you luck bro
- Cyanide_
What exact issue did you have, and how have you fixed it? Have you tried other places if your house causes stutters no matter what? Are you sure it's not electricity/grounding/emf problem, which can also cause low fps/stutter/desync/lag and so on? Do you have any "before" and "after" footages? Btw this is input lag forum so...
lavar
BTW this isn’t just an input lag forum “
And uhh yeah dude, I wish it was a grounding problem.
Are you sure your input lag problem isn’t a grounding problem man? You should call an electrician and get your outlets checked asap! Maybe buy some greenwave EMF filters man you never know.
Issue was explained in post.
I knew this post would get bombarded w input laggers coming in here. The other 500000 forums aren’t enough apparently.
