TPM 2.0 and Secure Boot Increases Lag! (Tested)
FPSMaster
Post by FPSMaster » 14 Nov 2023, 04:11
Recently, a youtuber named 'Tech Yes City' did a comparison Video between Windows 10 vs Windows 11 and found out that W11 has more latency.
It's pretty interesting to see what he tested. He specifically compared TPM, Secure Boot on vs off and saw a 3ms reduction in Lag (mouse movement to photon delay), just by disabling these settings inside bios.
Also, he showed that disabling backround services and tune/debloat windows does make a big difference for Latency, no matter which windows version.
I'm happy to see someone finally testing these things, because it was in debate that these settings decreases lag.
So yeah, debloating, tuning your windows install DOES make a difference!
Here is a link to his Video: https://www.youtube.com/watch?v=CDqOLJzwcuo
EDIT:
Here is the last windows 10 optimization guide he speaks about in his video: https://www.youtube.com/watch?v=FmbsLnp3iIA
He showed couple of tweaks that are really hidden inside Windows.
TheKelz
Re: TPM 2.0 and Secure Boot Increases Lag! (Tested)
Post by TheKelz » 14 Nov 2023, 05:06
FPSMaster wrote: ↑
14 Nov 2023, 04:11
Yes, some tweaks do indeed work. I recently decided to try using some tweaks and debloated my Win 10 install. My PC is now flying and is so responsive it almost feels like I jumped from an HDD to an SSD even though this whole time I had an NVME. I also disabled Secure Boot on my old Celeron laptop with an HDD and it also made a pretty dramatic difference in performance. Although this still does not help with the input lag though, there are other things that actually affect it.
FPSMaster
Post by FPSMaster » 14 Nov 2023, 05:24
TheKelz wrote: ↑
14 Nov 2023, 05:06
FPSMaster wrote: ↑
14 Nov 2023, 04:11
Glad it helped for you :)
I use WinUtil by ChrisTitusTech btw, it's a great tool to debloat windows, disable services/power saving features in a fast way. I always use it with every windows 10 or 11 installation. Works great.
But sure, there are other things which have a bigger effect, FPS of course or Frame Times.
Still interesting to see, that these settings reduce latency by like 5ms or even more.
TheKelz
Post by TheKelz » 14 Nov 2023, 05:34
FPSMaster wrote: ↑
14 Nov 2023, 05:24
TheKelz wrote: ↑
14 Nov 2023, 05:06
FPSMaster wrote: ↑
14 Nov 2023, 04:11
Interestingly, I used his tweaks as well, particularly that powershell command tweak which has everything in it. :) Brings processes from 140 to about 75 on a fresh boot. Then deleted most MS apps using powershell and did some other stuff. Pretty fast system now.
unconnected
Post by unconnected » 14 Nov 2023, 08:16
You guys should try AtlasOS w11, it has been released a couple of days ago
FPSMaster
Post by FPSMaster » 14 Nov 2023, 10:43
unconnected wrote: ↑
14 Nov 2023, 08:16
I heared alot of great things about AtlasOS, maybe I gonna try it out next time I wanna install W11.
amorou
Post by amorou » 15 Nov 2023, 22:23
FPSMaster wrote: ↑
14 Nov 2023, 04:11
EDIT:
Well changing some stuff in windows OS will destroy your mouse movement (not lag)
So most of the stuff do not worth to do
I can give thousands of examples but here 1:
Do not do it unless you willing to do system restore or reinstall
Device manager: Delete print queue stuff , now your mouse movemet is much worse.
FPSMaster
Post by FPSMaster » 16 Nov 2023, 05:39
amorou wrote: ↑
15 Nov 2023, 22:23
FPSMaster wrote: ↑
14 Nov 2023, 04:11
EDIT:
What make you think to believe this?
Disabling unnecessary services, settings and optimize windows generally lowers overall cpu utilization and interrupts etc. Which helps in lag.
Sure, some stuff is dangerous to touch. For example changing things in the registry can actually break your whole windows install.
Windows comes with so much bloat and stuff, that isn't made for latency sensitive multimedia tasks. Microsoft just aims to provide the most casual, user friendly experience you can have.
They implemented these things, so windows is working even on really old systems.
For example, memory compression. It works by compressing the data inside your ram, so people with low amount of ram (like 8gb) wont have problems.
This has a negative impact on cpu utilization, because now the cpu needs to compress and decompress data ALL THE TIME, file by file.
In games, it lowers your 1% and 0.1% drastically, resulting in frametime fluctuatins.
There are many other examples, but its too much ^^
amorou
Post by amorou » 16 Nov 2023, 05:42
FPSMaster wrote: ↑
16 Nov 2023, 05:39
amorou wrote: ↑
15 Nov 2023, 22:23
FPSMaster wrote: ↑
14 Nov 2023, 04:11
EDIT:
Disabling unnecessary services, settings and optimize windows generally lowers overall CPU utilization and interrupts etc. Which helps in lag.
But generally, windows comes with so much bloat and stuff, that isn't made for high sensitive multimedia tasks. Microsoft aims to provide the most casual experience you can have.
Well go try and see
I know less interrupts are sweet , all Im saying not every theoratical good stuff makes it better always
FPSMaster
Post by FPSMaster » 16 Nov 2023, 06:11
amorou wrote: ↑
16 Nov 2023, 05:42
FPSMaster wrote: ↑
16 Nov 2023, 05:39
amorou wrote: ↑
15 Nov 2023, 22:23
FPSMaster wrote: ↑
14 Nov 2023, 04:11
EDIT:
Well go try and see
Speaking about printers, if you think it actually makes things worse for you, sure... then don't mess with it.
But, I saw many guides, tests with high fps slow-motion cams that measured the latency of fully optimized systems. 2 of these tests had devices and services, like the "printer queue" and "fax" disabled.
They still saw major reductions, both in mouse click to photon latency and mouse movement to photon latency.
The video I posted also included this.
I also don't know how it would affect your mouse movement in any negative way. It's simply a service that runs in the backround checking the USB hubs for connected print devices.
It doesn't change how the mouse behave, like mouse settings or usb throttling.
