Should I disable FreeSync Premium on my monitor if I don't use it?
OniiChan69
Post by OniiChan69 » 17 Dec 2023, 16:10
I'm currently using an HP x24ih gaming monitor which has FreeSync Premium. The monitor is connected to my laptop using an HDMI 2.0 cable. Here's the thing: my laptop happens to have an NVIDIA GPU, which means I can't utilize the benefits of FreeSync Premium. So, I've been wondering whether it would be wise to disable the setting directly from my monitor's OSD control panel.
Ittara
Re: Should I disable FreeSync Premium on my monitor if I don't use it?
Post by Ittara » 23 Feb 2024, 16:41
Someone with more knowledge than me will probably be more helpful but in the mean time Yes you can use FreeSync with and Nvidia GPU.
toprak
Post by toprak » 29 Feb 2024, 03:08
Incorrect my friend, I have Lenovo Legion R25i-30 which has FreeSync Premium I also have RTX 3050 on my setup so we can say that we are on same boat. I can utilize it very well. You should check the 3rd option on gsync section on the panel.
