Screen flickers at some HZ value
Posted: 22 Dec 2023, 13:04
I have a very cheap noname 1440p 144hz monitor (SUN-M27BA108) which support VRR.
I can turn on gsync throuh vcidia control panel and see what VRR actually work.
But there is a problem - at some hz values (random constant value in range of 90-110hz) screen starts to flicker(full screen blanks or right part of screen blanks) and frameskip.
[Mod - Edited to fix VIDEO url]
you can see this bug in this video, constant 105fps-105hz causes flickering.
Also flickering occures at constant 53fps/105hz.
If I turn on 120hz mode, screen will be flickering at 90hz.
If I overclock monitor to 155hz it will flicker at 65 and 130fps.
When I make custom 90hz resolution - VRR works withput any problems.
At 110hz mode(through custom resolution) I see weird bug -frames' displacement( some frames renders in wrong place)
I ve tried to change vrr range - no luck.
I ve reinstalled drivers with ddu - no luck.
Only 90hz is fully playble mode.
Any suggestion what;s wrong with my system (monitor> cable . os. gpu)?
Any suggestions to fix this?
