Hi I’m looking for some information on an issue I’ve ran into on the PG27AQDM displays that I can’t find any information on. Essentially sometimes vertical banding is really bad and sometimes it is clean.
Typically whenever I turn it on after it’s been off for over 30 minutes or so I will get the intense banding and I’ll have to have it on for awhile and a pixel refresh will clean it up again. Sometimes though a pixel refresh will make it go from clean to intense again though. Sometimes I can turn it on after a whole night and it will be clean. When it’s intense I get a lot of Venetian blind/Mura effect as well.
Has anyone experienced this before? I’m aware banding can change somewhat after refreshes and other factors but on these monitors it’s always a big difference and the banding is in the same spots if it’s intense.
Any help would be great!
Asus PG27AQDM vertical banding
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
