Asus vg248qe INF issues.
gobbles04
Hey guys hope everyone's day is going well. So im having some problems with my asus gsync DIY kit monitor. Came back from a trip to the store and my monitor would not work, menu button displayed gsync monitor but all the fields were blank. I tried reformatting, uninstalling drivers with DDU nothing worked until this morning when i used your lightboost EDID override hack and suddely i got a picture but it would only max out at 800x600. I think the issue is that that hack was using the non gsync EDID info. Can anyone post me a .inf of the gsync capable DIY kit? Any other options or ideas would be greatly appreciated. THANKS!!
gzboli
Re: Asus vg248qe INF issues.
I think you should contact nvidia about this instead of trying to find a software fix. From what I've heard they've been good about helping out with DIY fixes/replacements.
Forums won't let me attach an inf or txt, so here it is:
Code: Select all
; INF file generated by Monitor Asset Manager (2.90.0.1000), 8/30/2014
; Copyright (c) 1995-2014, EnTech Taiwan.
; Internet: http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=8/30/2014, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\NVDFFFE
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\NVDFFFE
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x3A,0xC4,0xFE,0xFF,0x32,0x38,0x38,0x38,0xFF,0x17,0x01,0x04,0xA5,0x35,0x1E,0x78,0x02,0xEE,0x91,0xA3,0x54,0x4C,0x99,0x26,0x0F,0x50,0x54,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x13,0x2B,0x21,0x00,0x00,0x1E,0x00,0x00,0x00,0xFF,0x00,0x23,0x41,0x53,0x4D,0x37,0x4C,0x77,0x73,0x48,0x43,0x47,0x33,0x64,0x00,0x00,0x00,0xFD,0x00,0x1E,0x96,0x1E,0xA0,0x21,0x01,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x47,0x2D,0x53,0x59,0x4E,0x43,0x20,0x32,0x34,0x31,0x39,0x31,0x30,0x01,0xFD
;Extension bloc #1, e.g., CEA-EXT, DID-EXT, etc.
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x0A,0x01,0x65,0x4B,0x04,0x00,0x01,0x1E,0x8A,0x4D,0x80,0xA0,0x70,0x38,0x2C,0x40,0x30,0x20,0x35,0x00,0x13,0x2B,0x21,0x00,0x00,0x1A,0xFE,0x5B,0x80,0xA0,0x70,0x38,0x35,0x40,0x30,0x20,0x35,0x00,0x13,0x2B,0x21,0x00,0x00,0x1A,0x86,0x6F,0x80,0xA0,0x70,0x38,0x40,0x40,0x30,0x20,0x35,0x00,0x13,0x2B,0x21,0x00,0x00,0x1A,0xFC,0x7E,0x80,0x88,0x70,0x38,0x12,0x40,0x18,0x20,0x35,0x00,0x13,0x2B,0x21,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xDF
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,0
HKR,,PreferredMode,,"1920,1080,60"
[MODE1]
HKR,,MaxResolution,,"1920,1080,60"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\1920,1080,60",Mode1,,"30.0-160.0,30.0-150.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
;YourColorProfileFile.icm for non-sRGB displays
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="NVD G-SYNC 241910 (NVDFFFE EDID Override)"
VENDOR="NVD"-
gobbles04
Thanks for the info! I did contact Nvidia and they are sending a replacement.
