Page 1 of 2
Latency Caused By Power Instabilities Caused by Computer Fans
Posted: 15 Jan 2024, 04:32
by r0ach
I ran an open case system for a long time with just a single fan on the CPU. Through iterations of that system I even had the fan plugged into an external outlet and not run through the PSU at all. I recently bought a "gamer" case with three fans in the front and one in the back to see if this excessive airflow would be good for my 7800xt.
No matter what configuration I connect the fans with whether it's each fan connected to an individual molex connector by itself or all fans connected to a single fan controller going to one molex power connecter, mouse movement is WAY heavier with all these fans connected. I will now be heading back to my single fan setup and will probably even power it externally bypassing the PSU.
Forget the people talking about EMF from radioactive pipes in the walls or UFOs, if you have heavy cursor movement (since it seems like a lot of you run an insanely high amount of fans) this is probably your main problem. As to why this issue occurs, can't tell you. Either the fans generate a field while running and feed noise into the PSU or maybe some PSUs just don't handle being pulled on by numerous small devices at once. I have a platinum Corsair (Great Wall OEM but it scores God-like in tests better than just about anything), so this phenomenon will probably be noticeable on many other (all?) PSUs.
Re: After 75 years I solved your input lag
Posted: 15 Jan 2024, 04:47
by ahead
I can confirm that every professional, when it came to playing the LAN disassembly case and reconnecting the fans, I saw that myself.
Posted: 15 Jan 2024, 04:54
by amorou
r0ach wrote:
15 Jan 2024, 04:32
Yes it is happening on all my psus , rmx750 , seasonic core 650 , aerocool vx400 , some tier A cooler master from 10 years ago
Also desoldering all leds from your mobo /pcie ethernet vs makes it better
Posted: 15 Jan 2024, 05:56
by beirut__
r0ach wrote:
15 Jan 2024, 04:32
So how do you propose that we cool our graphic card
Posted: 15 Jan 2024, 09:34
by Vocaleyes
r0ach wrote:
15 Jan 2024, 04:32
I wonder how AiO’s are impacting this issue if this is the case?
Posted: 15 Jan 2024, 09:56
by kriegsnake
beirut__ wrote:
15 Jan 2024, 05:56
r0ach wrote:
15 Jan 2024, 04:32
Posted: 15 Jan 2024, 10:56
by dervu
kriegsnake wrote:
15 Jan 2024, 09:56
beirut__ wrote:
15 Jan 2024, 05:56
r0ach wrote:
15 Jan 2024, 04:32
Image :lol:
Posted: 15 Jan 2024, 12:47
by RealTweaker
dervu wrote:
15 Jan 2024, 10:56
kriegsnake wrote:
15 Jan 2024, 09:56
beirut__ wrote:
15 Jan 2024, 05:56
r0ach wrote:
15 Jan 2024, 04:32
Image :lol:
The fridge will also block out EMI
Posted: 15 Jan 2024, 18:31
by andreeeeee-
Hey, r0ach, glad to see you here.
Your threads on OCN basically founded the tweak community.
About your finding, for anyone interested in this issue regarding fans/molex, there is an almost 10 year old thread on OCN discussing it: https://www.overclock.net/threads/after ... em.1524063
Posted: 15 Jan 2024, 21:44
by r0ach
andreeeeee- wrote:
15 Jan 2024, 18:31
The fan issue is kind of a complex subject. On my setup it feels like each additional fan brings an additive effect to creating heavier cursor movement (and maybe some types of fans are worse than others - no idea yet). If someone prefers heavier cursor movement for aim they might not see this as a problem. I could see people removing four fans from their PSU and noticing mouse movement feels 1/10th as heavy and actually playing worse.
Some people hit the lottery on their builds and it just winds up ideal for their aim with the random parts they bought. For other people, you have to add or remove components if something is causing a problem. For my current setup, I run 7800xt with modded/stripped AMD drivers installed via driver only mode. Mouse movement is more sensitive than any Nvidia drivers released in the last several years. With the combination of removing all the fans + the stripped AMD drivers, I play better at 1440p because it's actually overly quick/sensitive at 1080p.
So as you can see, depending on your preference for heavier or light cursor movement and each person's hardware variables, issues like this are going to range from no problem to enormous problem for some people. Having four fans plugged in feels overly heavy for me with any combination of variables, though.
