disable ioapic 24-119 entries when using msi mode its conflict the IRQs on gpu/mouse its fix the deadlock between the interrupts
if anyone tell u its reduce the latency its a lie its create more IRQs for more troubles when u on msi mode
Re: отключить записи ioapic 24-119
Need to off if u use msi mode
Re: disable ioapic 24-119 entries
grub / scewin
Sebichek45
what is its equivalent in amd? I search for the iopic and it shows for intel only.
