Page 1 of 2
Mouse poling rate unstabe
Posted: 12 Feb 2024, 14:35
by popugbird
So i have few mouses: xtrfy m42, starlight 12, model 0-, g102, g305.
All usb power savings windows/bios disabled.
Mouse plugged to different usb controller that mapped to different cpu core with Interrupt Affinity Policy Tool.
And when i go to mouse rate checker my poling rate depends on how fast i move mouse. Slow movements provide 300-400 hz (this moves simmilar to tracking enemys in apex/kovaak scenarios etc) and 1000hz achived only by fast moves.
Is this possible to force mouse works at 1000 hz all the time?
Re: Mouse poling rate unstabe
Posted: 12 Feb 2024, 14:37
by ptuga
increase dpi and or lower sens.
Posted: 12 Feb 2024, 14:38
by xShino
Is this not the norm? Why do you think this is a problem?
Posted: 12 Feb 2024, 15:00
by popugbird
xShino wrote: ↑12 Feb 2024, 14:38
Because slow moves provide you low poling rate that means mouse sends less data to cpu and u have higher input lag in almost every scenarion other than doing 480 flicks.
Posted: 12 Feb 2024, 16:29
by xShino
But do you think there are people that have 1000hz while doing small mouse movements? AFAIK there are none.
Posted: 13 Feb 2024, 10:43
by Noirpirate85
xShino wrote: ↑12 Feb 2024, 16:29
but shouldnt it be that way that the mouse is constantly reporting at a 1000hz so that the mouse always tracks with the same amount of information no matter if you track 1cm or 10 its should report the moved route/ track even when you dont move it should use 1000hz to
but maybe this is wrong because
a monitor refresehs also every 144times a second and when your frames dont match you get tearing but on the other hand if you have freesync it refresehes with the amount of pictures been send from the gpu if its in the hz/frames range of the monitor
Maybe thats the reason why the poling rate isnt constant at all
Posted: 13 Feb 2024, 11:05
by xShino
In my opinion? Yes, I would also think that it would be better for the mouse to report 1000hz on every movement.
But I'm not good with the technical side to this so I can't answer why it is like that.
Posted: 13 Feb 2024, 21:07
by RealTweaker
I don't think testing polling rate with a website is reliable. The browser you are using may handle polling rate in a wrong way or something, test with mousetester instead.
Posted: 13 Feb 2024, 23:26
by Haste
Just increase your dpi and that will fix it.
Posted: 14 Feb 2024, 03:18
by xShino
Are you both saying, that you don't have this "problem"? If so, I'd like to see proof of some kind.
