XG2431 PureXP & Overdrive
4nlv
Post by 4nlv » 13 Feb 2024, 02:51
Everytime I use PureXP, the Overdrive (Response Time) setting gets disabled entirely.
Does PureXP have a different overdrive setting or does it also use the same one that is disabled? (which in my case is Ultra Fast)
Re: XG2431 PureXP & Overdrive
Post by RealNC » 13 Feb 2024, 07:51
4nlv wrote: ↑
13 Feb 2024, 02:51
viewtopic.php?p=46640#p46640
4nlv
Post by 4nlv » 13 Feb 2024, 13:10
RealNC wrote: ↑
13 Feb 2024, 07:51
4nlv wrote: ↑
13 Feb 2024, 02:51
thanks for this!
if it's possible to answer, are the response times and input lag of the PureXP modes as fast and low, or at least as close to 4ms response time and 2.7ms input lag on native resolution @ max hz that is listed on RTINGS, where PureXP off and OD set to Ultrafast?
