Grounding PC case
Grounding PC case
Post by Slender » 29 Feb 2024, 12:57
Im see that guide https://www.youtube.com/watch?v=9esauzfuDiQ&t=609s, this guy says that you must strip all the contacts from the case to the motherboard (there are 9 of them), that is, all 9 screws must drain current to the case. Is it correct? I think it would be correct to use 8 non-conducting racks and only one rack at the bottom of the board that conducts current. But he claims that all 9 bolts must conduct current to the case. I always paid attention to the fact that the case is always supplied with 1 gold stock and all the other regular ones (black)
Thatweirdinputlag
Re: Grounding PC case
Post by Thatweirdinputlag » 29 Feb 2024, 13:33
It's actually interesting that you have only one gold stand-off screw. I just checked mine, and all of them are black! Did you try to use the golden one instead of one of the blacks?
MegaMelmek
Post by MegaMelmek » 29 Feb 2024, 14:15
waste of time i try both of them it will do not help
you but the gold are cheap you can get them on aliexpres
Post by Slender » 29 Feb 2024, 15:32
Thatweirdinputlag wrote: ↑
29 Feb 2024, 13:33
i have 9 of this gold, in all case complect it be only one. No, im just scratch black stand-off and install board with silver screws.
Im not see big improve, maybe nothing of worse. but im make like that.
Unreazz
Post by Unreazz » 29 Feb 2024, 18:36
Is this the WinkliYT guy? I don't really trust him. He seems to be someone who believes more in placebos and claims to have fixed something without actually making any real improvements. For instance, he asserted that he fixed Valorant's hit registration with RAM timings.
d-unknown
Post by d-unknown » 02 Mar 2024, 14:08
Unreazz wrote: ↑
29 Feb 2024, 18:36
yes it's the guy who claims that rgb strips helps hitreg , and white cases are better than black ones as it fix desync
