Blur Buster's 1000hz journey ending at 650hz OLEDs?
tong
Post by tong » 09 Mar 2024, 18:46
Now that we've seen what high refresh OLEDs are capable of when it comes to motion clarity, it's evident that thanks to the near-instant response times, the blur is lower compared to LCDs at the same refresh.
TFTCentral states that a 360hz OLED looks like an LCD at 540hz:
https://tftcentral.co.uk/reviews/dell-a ... e-aw2725df
An OLED has an approximate 1.5 to 1 ratio of motion clarity to an LCD screen, and you can see that the 360Hz OLED panel is close to the 540Hz LCD overall (i.e. 360 x 1.5 = 540).
So, does that mean the 1000hz clarity journey is now actually a 650hz journey for OLEDs?
hart
Re: Blur Buster's 1000hz journey ending at 650hz OLEDs?
Post by hart » 28 Mar 2024, 08:55
then, the journey to maintain 650fps without drops will start
Displays: Dell AW2725DF + LG 27GL850B + LG Dual-UP 28MQ780 PSU: Corsair HX850i Mobo: B650E-E CPU: 7800x3D Cooling: Arctic LiquidFreezer III 420 RAM: 32gb DDR 6000 CL28 GPU: Strix 4090 SSD: Samsung 990 PRO 4TB + WD SN850X 2TB Mice: G-wolves HSK pro 4K + Razer Naga V2 pro Keyboard: Wooting 80HE Sound: Topping DX7 Pro+ (using optical) / HifiMan Edition XS / Bose QuietComfort Ultra OS: W10 pro
Supermodel_Evelynn
Post by Supermodel_Evelynn » 05 Apr 2024, 14:48
1000 FPS is NOT a realistic goal even with computers coming out 30 years into the future we will all long be dead by the time a PC can maintain 1000 FPS in any AAA title
LCD Strobing or OLED BFI and brightness needs to improve so we can maintain realistic goals
I have a decent PC and I can barely maintain 60 FPS in Warhammer 40K Darktide even on 1080P medium settings in chaotic fight scenes.
There is hope with GSYNC pulsar but that isn't 1000 HZ
ssamowo
Post by ssamowo » 05 Apr 2024, 17:15
persistence still gets reduced the higher the hz, regardless of framerate, doesn't it? only strobing needs framerate to = hz, to avoid double images. 1000hz would not have this issue presumably so 60hz games would still have great motion clarity on 1000hz monitors, is what i believe the case would be.
Post by RealNC » 05 Apr 2024, 17:46
ssamowo wrote:
05 Apr 2024, 17:15
Nope :) You need high FPS and high Hz to get lower motion blur. If the game runs at 60FPS, then 60Hz, 280Hz, or 480Hz (or 1000Hz if that ever appears) will have the same motion blur.
Post by jorimt » 05 Apr 2024, 18:35
RealNC wrote:
05 Apr 2024, 17:46
ssamowo wrote:
05 Apr 2024, 17:15
Yup, no further motion blur reduction, but less visible tearing and overall latency at 60 FPS (or any framerate) the higher the physical refresh rate with G-SYNC or no-sync at least though.
Displays: ASUS PG27AQN, LG 48C4 Scaler: RetroTINK 4k Consoles: Dreamcast, PS2, PS3, PS5, Switch, Wii, Xbox, Analogue Pocket + Dock VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
thatoneguy
Post by thatoneguy » 10 May 2024, 02:24
Supermodel_Evelynn wrote:
05 Apr 2024, 14:48
That is where Framegen comes in. You render 100fps and framegen the rest to a 1000fps.
AI will also play a role.
Supermodel_Evelynn
Post by Supermodel_Evelynn » 21 Jan 2025, 09:27
thatoneguy wrote:
10 May 2024, 02:24
05 Apr 2024, 14:48
Yes if you love blur and artifacts and a frame gen tech that only works in 0.1% of games then yes frame gen is good for 1000 FPS
JimProfit
Post by JimProfit » 25 Jan 2025, 10:01
21 Jan 2025, 09:27
I'm the first to say that at this point frame-gen isn't perfect and not yet a fully viable replacement for LCD backlight strobing (wherein 1ms MPRT is possible).
However I wouldn't say it is as bad as you suggest.
The toolbox that Lossless Scaling provides is very compelling, for reasons other than frame-gen too, and it works for every game on basically any GPU that can provide a solid base.
And Nvidia appears pretty much dead set on pushing that technology forward with every new architectures.
It is THE solution when we want to conjugate both HDR brightness levels and clear motion, in the future when we get no-compromise high-refresh panels. Hopefully it does gets its artifacts sorted out in due time.
LG OLED65G1 - LG OLED55GX - Panasonic 58EX780E - Pioneer KRP500A - Sony D24E1WE (ooo) - Toshiba 288DF
Asus PG27VQ - Asus PG278QR - Sony FW900 - Iiyama HM204DT - Mitsubishi 2070SB
Purpose
Post by Purpose » 25 Jan 2025, 16:31
jorimt wrote:
05 Apr 2024, 18:35
RealNC wrote:
05 Apr 2024, 17:46
ssamowo wrote:
05 Apr 2024, 17:15
The relationship is nuanced is all I can say for sure from personal experience.
I hooked up my FW900 CRT, created a 150hz resolution that pushes 500fps in low res on Delta Force Blackhawk.
60hz looks good but the refresh is so choppy. I’m used to my 240hz G9 OLED.
But at 150hz, when the frames stay over 300, it eliminates or at least hides perceived screen tearing, motion blur, absurdly low input latency. (No wonder I used to snipe so good in CS in 2002)
This is kind of the reverse argument to what you’re saying since I’m talking about frames above refresh and your talking about refresh above frames
BUT.. like I said in the beginning.. you FEEL the refresh rate regardless of whatever else is going on.
Like I can’t even function on a 60hz monitor.. barely at 120hz even on the desktop.
My 240hz is drastically better feeling than my 165hz screens.
So I’d rather have 480hz no matter what on anything other than CRT
