Page 1 of 2
Emulator settings
Posted: 14 Mar 2024, 12:44
by Vegeta
Hi guys, do you know what might be Bios settings and non-Bios settings that positively and negatively affect pc game emulators? For example RPCS3 and other... I have some Desync issues, and I would like to figure out what I could change and see maybe some changes from it. I have amd 7800 processor.
Re: UDP packet always UNREPLIED.
Posted: 15 Mar 2024, 11:37
by Slender
call isp
Posted: 15 Mar 2024, 12:54
by Vegeta
Slender wrote:
15 Mar 2024, 11:37
call isp
I did, but they tell me there is nothing they can do.
Is it normal that by doing the server tracert only 10 of 22 addresses come out?
Posted: 16 Mar 2024, 04:53
by Slender
Vegeta wrote:
15 Mar 2024, 12:54
Slender wrote:
15 Mar 2024, 11:37
call isp
no
Posted: 16 Mar 2024, 05:27
by Vegeta
would you please help me?
I called ISP but they can't do anything about it.... so they told me. is there anything I can do?
Posted: 16 Mar 2024, 07:13
by cursed-gamer
Vegeta wrote:
14 Mar 2024, 12:44
Hi guys, I hope I am not mistaken where I am posting this topic. Feel free to move it admin, no poroblem.
So, I play a ps3 emulator, it is called RPCS3.
I have a 7800x3d and a 7900 xtx as my gpu.
I always experience problems with HIT REG and desync.
I found out from the modem ( ax6000 Asus) that all the packets that RPCS3 uses, i.e. UDPs, are always UNREPLIED.
Those few times that UDPs result "ASSURED" ( which would be my goal) the game works fine.
The port we use to host ( I play in P2P ) is 5730, and the server we rely on has this ip 15.204.66.207.
I have also done a tracert of this address, and out of 22 replies only 9 at times 10 replies.
I would like to know, is there any possibility to solve this problem?
if you need to know anything, please write to me, there is no problem.
There is no feedback in UDP, you just bomb server with datagrams and there is no any handshake, reply, acknowledgement etc.
Posted: 16 Mar 2024, 07:45
by Vegeta
ah okey...so what can I do? do you have any suggestions?
Posted: 16 Mar 2024, 12:37
by cursed-gamer
Nothing, this is the nature of UDP. If your ISP sucks at handling it, then there is nothing you can do.
Posted: 16 Mar 2024, 20:12
by Aeodyn
If your ISP is treating UDP differently than TCP, the solution is to use a VPN.
Posted: 17 Mar 2024, 02:59
by Vegeta
With VPN (North) the connection got worse... but I never did test or tracert with vpn, can I try?
Then I didn't understand one thing: do you also have the tracert problem ( for example) in the sense that you try to do the tracert of the server I put in gives you the same results? Or is the udp packets the problem?
