useplatformclock (Windows stutters)
LaggyTyp
Post by LaggyTyp » 07 Apr 2024, 16:29
Hello folks. When I run the following command and restart Windows, I immediately notice that everything (e.g. opening Firefox) is taking longer and it's getting worse by the minute. I once managed to get into BF2042 and only had ~35 FPS, even though I'm always in the FPS limit (144).
bcdedit /set useplatformclock true
Why does my PC freak out when I try to activate HPET?
PS:
12900K
Asus Strix Z690
DDR4
Windows 10
LaggyTyp
Desync in all Games (Fix)
Post by LaggyTyp » 08 Apr 2024, 08:35
I've been suffering from a desync problem for a long time. Everyone is one step ahead of me and I don't die normally with damage, but instantly. My shots arrive (I see blood), but do little damage. With enemies that are far away, I don't get any hit markers. It's like I'm playing in the past for 1 second.
I freshly installed Windows = no improvement
Tried all the tweaks I could find = Nothing but placebo
By a great coincidence I was able to find the problem.
bcdedit /set disabledynamictick no
My games are working very well again. But why does this have such a dramatic impact?
LaggyTyp
Re: useplatformclock (Windows stutters)
Post by LaggyTyp » 09 Apr 2024, 03:53
HPET Off = 10.00 Mhz (TimerBench 1.5)
HPET On = 19.20 Mhz (TimerBench 1.5)
Normal?
Post by Slender » 09 Apr 2024, 13:19
bcdedit /deletevalue useplatformtick
bcdedit /deletevalue useplatformclock
bcdedit /deletevalue tscsyncpolicy
bcdedit /deletevalue disabledynamictick
LaggyTyp
Post by LaggyTyp » 09 Apr 2024, 13:34
If I delete "disabledynamictick" then my games are desynchronized again. My bullets no longer hit the targets, etc.
LaggyTyp
Post by LaggyTyp » 10 Apr 2024, 10:26
Today I switched from Windows 10 Pro (22H2) to Windows 11 Pro (23H2) and didn't change any settings.
Things are going really badly in BF2042.
- Hits are not registered correctly (hit markers but without causing damage)
- I'm dying behind cover
- Distant enemies cannot be hit (no hit markers)
- It feels like I'm ~500ms in the past
I live in Germany. The server is in Germany. My ping is 8-10ms.
I know that all this goes away when I run the following command, but why is that? Why no one else?
beirut__
Post by beirut__ » 10 Apr 2024, 12:15
I dont understand why do you mind it being that way? You discovered a solution to your problem, so why not enjoy your games now when they are working good?
LaggyTyp
Post by LaggyTyp » 10 Apr 2024, 12:49
I want to understand it.
- I want to understand why my system feels so extremely terrible with HPET? (everything is wrong)
- I would like to understand why HPET shows me 19.2 MHz?
- Is it due to my old BIOS? (Asus Strix D4 Z690 with 0901 Bios)
- Is it because of my OC? (12900K to 5.5Ghz + 4133MT DDR4)
- I want to understand why a standard Windows setting can have such terrible effects?
- Maybe there's more to it? Maybe you can “find” and “optimize” even more?
The 19.2 MHz (TimerBench/QPC mode) irritates me in particular? Without HPET it is 10 MHz.
LaggyTyp
Post by LaggyTyp » 11 Apr 2024, 04:34
I think the 19.2Mhz (QPC) comes from the motherboard. HPET is not supposed to exist at all on this motherboard. But I could swear that I once saw 24.0Mhz (QPC) on mine.
Asus Strix D4 Z690 (BIOS-Version 0901)
dermodemon
Post by dermodemon » 11 Apr 2024, 12:44
so what commands should i type for hpet if i have exactly same situation?
i have it like that
https://imgur.com/a/FVQsuTp
