Image resizing on main CS2 acc
Posted: 12 Apr 2024, 13:28
by faust123
Hello everyone
Im experiencing issue with CS2. When I launch the game from the main account the game rescales after the valve logo. Looks like cs2 seems to minimize and fullscreen again. There are no such problems on the second account. I have a video (but cant attach youtube) taken on camera since obs does not detect the problem. All settings are identical. PC is the same. Time between videos about 30 sec.
Game experience on the main account is way worse.
Do you have any ideas what it can be?
Re: Image resizing on main CS2 acc
Posted: 13 Apr 2024, 07:05
by RealNC
faust123 wrote: ↑
12 Apr 2024, 13:28
Moved to off-topic.
Posted: 13 Apr 2024, 10:58
by faust123
Found some difference
On main account when I type sys_info in console it says "render 1280x1024; display 1280x1024"
On smurf it says "render 1280x1024; display 1920x1080"
You can check it in attached screenshots.
Every other settings are similar.
Posted: 13 Apr 2024, 11:18
by RealNC
Check whether or not you have launch options set in one of the account but not on the other.
Posted: 13 Apr 2024, 14:51
by faust123
RealNC wrote: ↑
13 Apr 2024, 11:18
There is no launch options on both accs
Everything is just the same
I double check settings, parameters etc
Posted: 13 Apr 2024, 15:47
by faust123
upd
fixed with cs2 reinstall (+ delete userdata 730 folder)
