Go solve your issues
amorou
Post by amorou » 30 Apr 2024, 18:18
Hire a electrican , tell him to tighten all eletrical contact points from buildings enterance to your flat
He/she will say there should be voltage drop if those contacts gone weak , just tell him/her to do it anyway
(They will have to cut electricity of entire building , if its problem for you just skip the enterance and do
your floor>meter in>meter out> your flat)
n1zoo
Re: Go solve your issues
Post by n1zoo » 03 May 2024, 00:59
Ok
amorou
Post by amorou » 03 May 2024, 20:56
n1zoo wrote: ↑
03 May 2024, 00:59
Ok
I wonder if you ve done any research regarding resistance on neutral line before deciding to type ok
loltakoo
Post by loltakoo » 04 May 2024, 01:12
you are an old user of this, in fact I'm surprised you made a post call an electrician after everything you've seen
f1ndus
Post by f1ndus » 04 May 2024, 01:34
amorou wrote: ↑
30 Apr 2024, 18:18
bro in 2018 i had 2 electricians and did everything new in my house, every single cable changed,every circuit and fuse box was new, problem still persist.
amorou
Post by amorou » 04 May 2024, 23:06
f1ndus wrote: ↑
04 May 2024, 01:34
amorou wrote: ↑
30 Apr 2024, 18:18
And your house was not a apartment I guess , if so do these electricians also changed wire that comes from street to your house?
amorou
Post by amorou » 04 May 2024, 23:14
loltakoo wrote: ↑
04 May 2024, 01:12
Well I did not told just call a electrician :D, I said there is a specific thing to be done
If there is severe looseness in neutral line your voltage will change , but a high resistance in path can not show such effect yet still can disturb electric motors, and everbody has electric motors in their home, refrigerators has 2 of them minimum
A apartment with 20 flats = 40 electric motors running on bad neutral and you share line with them vs
