240hz QHD Recommendation + Innocn 27G1S Plus Discussion
Posted: 04 May 2024, 16:49
by Saturnine
First post, so apologies in advance if I've done something wrong. I looked around a bit and used my best judgement to start a new discussion here.
I really enjoyed my brief experience with the original 27G1S VA panel, but had to return three separate 27G1S units due to a really awful artifacting that seemed to occur when the image was displaying tightly grouped alternating dark/light pixels. Maybe that's what I get for trying the open-box units.
I recently saw on Amazon that there is an "Innocn 27G1S Plus" monitor, which piqued my interest, but this monitor is advertised as IPS instead of VA. I thought that was a strange choice to give this panel the same name as existing VA panel when the LCD type is not the same. However, the 27G1S had some very impressive performance and I'm curious about the 27G1S Plus as well.
Does anyone have any information on the 27G1S Plus panel? I'm not sure when it was officially released, so there may not be any available information.
I'm currently looking for a 1440p 240hz+ panel at reasonable price, and have not particularly impressed with the offerings. I purchased the Asus VG27AQML1A for $230 on a deal from Amazon, and think I will return it. I would describe the motion clarity as poor. I think the LG 27GR83Q is using the same panel, which means I can probably count that out as well. I would maybe consider the Asus XG27AQMR if it was a little more reasonably priced, but it seems to be not too much better than the VG27AQML1A, at nearly twice the cost. Not to mention, for $550+ USD, we get pretty close to QHD 240hz OLED prices.
I would buy the original 27G1S VA panel in a heartbeat if it came back in stock in new condition, but I think they may have discontinued the production. Maybe the 27G1S Plus will fit the bill? Curious what anyone knows or has to say.
Thanks!
Re: 240hz QHD Recommendation + Innocn 27G1S Plus Discussion
Posted: 26 Jul 2024, 14:47
by badvertisement
I just made an account to reply.
Sorry you never got a response but I believe I had this same issue with my VA 27G1S at 240Hz over DP but not at any other (preset) refresh rate or over HDMI. I wrote into Innocn support and they told me this is a firmware issue so they sent me a firmware update in the form of a bin file and I'm still following up trying to figure out how to update my monitor.
If you haven't checked out Monitors/Hardware Unboxed and Techless on YouTube I'd highly recommend it, their reviews and testing are what led me to try the 27G1S. If you're still in the market after all these months, the main recommendations for 1440p 240Hz are the MSI G274QPX and LG 27GR83Q, with the LG being marginally better than the MSI but not enough to justify a significant price delta.
Posted: 26 Jul 2024, 17:21
by kyube
Saturnine wrote: ↑
04 May 2024, 16:49
The 27G1S Plus uses the M270DAN08.0, which is employed by the XB273U GX, according to this
Should be akin to other 1440p240hz IPS models, nothing extraordinary about it.
Posted: 27 Jul 2024, 08:26
by RealNC
Saturnine wrote: ↑
04 May 2024, 16:49
Issues like this is what made me bite the bullet and order a 27" 1440p 240Hz OLED. Even though I could be ordering monitor after monitor and if it's crap I can just send it back, no questions asked, it's just too time consuming. I did it once last month, and the whole procedure took almost a whole month.
If you're patient (unlike me :P) and can return the displays if they're crap, then yeah, go for it until you find one you actually like. But as a starting point, I would consider the various "best monitor 2024" lists that sites like rtings and pcmonitors.info maintain.
