Refresh Rate on Benq EX2510S Osd Not Fluctuating With Freesync On
Posted: 07 May 2024, 04:32
I've tried enabling freesync everywhere, my monitor says freesync premium on, my amd driver says my freesync is enabled with 48-165 range, but whenever I open a game or a test application like nvidia pendulum or amd windmill my osd refresh rate is stuck at 165hz and it never fluctuates. Going by this forum, this means freesync isn't working.
I'm on windows 11 23h2, with amd rx 6800
I have freesync enabled in amd driver->gaming>display, and under the specific game profile as well, and in windows 11 system->display->graphics->default graphics settings I have vrr enabled.
My monitor has freesync on by default granted I don't enable the blur reduction option.
According to the manual, freesync premium works with hdmi or display port, I tried using both and had the same result.
What should I try to check to get freesync working?
