[Bad LOD in Games | Juddering PC] Management Engine(Locked/Damaged) - Enhanced i/o issues [Closed/Not Relevant]
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers. Introduce yourself!
Locked
naporitan
Post by naporitan » 12 May 2024, 03:22
:!: Link - https://youtu.be/j9TgNFu1l3Y (in the comments below the video, the author shares his research, I recommend that you familiarize yourself.)
I would like to discuss this video.
[Moderator Note: Topic edited upon OP request]
dermodemon
Re: [Bad LOD in Games | Juddering PC] Management Engine(Locked/Damaged) - Enhanced i/o issues
Post by dermodemon » 12 May 2024, 05:11
interesting. i wish i could disable PSP on my b450m pro4-f to test this
naporitan
Post by naporitan » 12 May 2024, 05:20
dermodemon wrote: ↑
12 May 2024, 05:11
You've got it all wrong. on the contrary, the subsystem must work otherwise you will remain in this universe. (to put it simply)
phx
Post by phx » 12 May 2024, 06:21
Under the video in which the author indicated the problem for testing, it is clearly written.
If the "video enhancer" works, the picture will be smooth.
Without processing, you will see jerks.
Gaming monitors generally don't have "Motion Smoothing" technology because it adds input lag.
However, some high-Hz monitors do not support <48 Hz when connected via a display port, some can only do this via HDMI.
hdmi30hz
hdmi30hz
The interpolation method is the most advanced. The processor analyzes two adjacent frames and forms an intermediate one between them.
Which is why dynamic scenes can “freeze” or, conversely, “jerks”.
24/48fps side-by-side comparison:
https://www.youtube.com/watch?v=8Ih7gOE4yew
Z3CrosS
Post by Z3CrosS » 12 May 2024, 07:38
I think that i don't think
delve
Post by delve » 12 May 2024, 09:25
there are some companies that offer PCs with disabled intel me, wondering if this could help or make things worse.
dervu
Post by dervu » 12 May 2024, 09:28
So it is enough to tell by comparing GPU load if you have this issue?
cursed-gamer
Post by cursed-gamer » 12 May 2024, 11:22
My GPU load was wrong on GTX 1660, RTX 2060 and RTX 3060.
MeveSPB
Post by MeveSPB » 14 May 2024, 06:48
Yesterday I watched all the author's videos and read all the comments.
This is all very interesting, but it is not clear to me how the author made a general conclusion from private observations that the reason is the correct combination of components CPU +PCH +INTEL ME + Windows retail.
I want to understand why such a conclusion was made?
Two systems are compared, one of which is perfect, the other is not. What does this mean? Not all computers display games in the same way — this is a fact that is 100% displayed in the video.
If we think further, these two systems are not identical, can we fairly find the reason for their incorrect operation? In one of the comments there was information that the theory was tested on 50 PCs, and somewhere the problem surfaced, somewhere not.
How can we say that this statistic gives us the right to draw an unambiguous conclusion? What exactly was evaluated, were they 50 identical systems or different ones?
How fair is it to compare systems with different bios settings (in particular voltage, etc.)?
Maybe it just so happened that on one of the systems, by a happy coincidence, everything worked as it should, but on the other system, the default values did not fit?
Are there such standards, and how adequate are they?
Since the issue of settings has not been raised, I assume that the author considers it not entirely significant. There is no answer to the question "why is this happening", but there is an answer to the question "how to avoid it" - it's luck.
1) First you have to win the "silicon lottery" - CPU+motherboard
2) You should also be lucky with the proper operation of the Engine Managment drivers.
3) You have one attempt not to break INTEL ME. If one of the system bundles is bad, it will ruin the whole system, without rolling back
4) Windows can break your Intel ME work, which is also not treatable.
The most interesting thing is how could it happen that there was a perfect system, but then it broke down due to a change of equipment (RAM and like a hard drive?).
Can a hardware change really break something in this INTEL ME black horse?
Correct me if something was misunderstood.
My folders are shaking, and I see image breaks on the video with Bruce (240Hz monitor), I have problems with PCI drivers, Management Engine, I/O (It starts only after removing devices -does MSI tech support say? that this is normal)/
I have new expensive hardware, Windows is really off, but am I still a loser?
Locked
