Fast enemies ferrari peaks and so (cs2 valorant input lag))
z3rg1ch
I dont know what to even think, after any tweak ang changing some settings and drivers my game changes. now I am in state where my enemies are not predictable at all, they are moving fast and not only when peaking also while changing direction its like faster than fast. When I see some vids of people playing they are almost in slo-mo when I need flash's superpowers to react and shoot. I am just thinking about leaving it (I mean competitive games). I will appreciate any kind of help)
- Slender
Re: Fast enemies ferrari peaks and so (cs2 valorant input lag))
you think that is ethernet issue or lag on your pc?z3rg1ch wrote: ↑15 May 2024, 18:15I dont know what to even think, after any tweak ang changing some settings and drivers my game changes. now I am in state where my enemies are not predictable at all, they are moving fast and not only when peaking also while changing direction its like faster than fast. When I see some vids of people playing they are almost in slo-mo when I need flash's superpowers to react and shoot. I am just thinking about leaving it (I mean competitive games). I will appreciate any kind of help)
dont apply any tweak if you dont know what is do.
Clear cmos (factory reset bios) and install w10 ltsc via Ventoy with revi-config
install nic / gpu driver and do not make any settings in os.
z3rg1ch
I think both. But on Ethernet it gets worse, so I use wifi (stable with 0 bufferbloat). I use win 10 with ventoy and revi cfg. I will try to clear bios and install ltct win
Do I need cpu chipset drivers or only gpu?
widow13
0 bufferbloat on wi-fi is probably because wi-fi has limits and cannot use all of the connection, if you don't get issues on ethernet just stick to it. And don't pay too much attention to bufferbloat. Bufferbloat exists when you are under heavy load.
So if you don't play while using ur full connection to download or only have 20mbps to work with, it's meaningless.
If that's not the reason try resolving the reason your ethernet is not working correctly.
You do need cpu chipset drivers.
xShino
How about recording it?
z3rg1ch
Ty guys, I’ll try to record and upload on yt
delve
I have this now since yesterday, when i spectate the entire game feels like almost 2x speed, this is on a game that hasn't been updated in years, super weird imo.
BumFlannel
What game? I went back and tried UT2004 which didn't have these issues back in the day on ISDN, 60hz and < 60fps at times. Now just playing instagib is like shots just go through people even though the hit box is just a huge capsule around the player model. Yeah in that game you have to lead targets to compensate for ping but back in the day I would shoot directly at them with like 50 ping and the shots would land, unless you were far to the opposite side of the direction the enemy was moving. Today with fiber and 10 ping shooting right at them doesn't work and neither does leading them, it's just random. Perfect net stats all around here.
CSS and 1.6 are just impossible to land shots in. I mean literally impossible. Outside of a random hit here and there there is nothing I can do. I used to be able to hit more shots in CS:GO before my issues started in 2015 just from pure chance with bad recoil control and spread aiming somewhere close to the enemy when today the cleanest of shots and sprays just don't get rewarded and my enemies just run and gun hitting with laser accuracy.
z3rg1ch
Bumping topic, cuz I still have desync when my enemies are unpredictable and fast. So this is not related to my network, because I have this on bots while offline. Tried msi util, not helping, now nothing changes, may be related to power and electricity but not sure. So if u have smth to try or test I’ll appreciate if u give me idea
akylen
Older pc dont have that problem , but i would be lying if i told you that i knew why
