24p BFI Solutions / Sources [SOLUTION: RT4K BFI]
Posted: 15 Jul 2024, 14:48
Hi all -- New to the forum and happy to be here.
I am wondering if anyone could point me in the right direction when it comes to reading up on whether (and how) BFI can be used with 24p sources. Principally: are there any displays or scalers that can use BFI to help with 24 fps stutter? If not, is such a solution even realistically feasible in theory? It looks like the Retrotink 4K does this to some extent, but I'm still working my way through that thread.
Details below about the specifics of what I'm wondering about, but in short, any resources relating prospects of BFI helping with 24 fps stutter would be helpful. I didn't see any relevant stickies, and searches brought up a few threads that were obviously on point but clearly dealt with software and technologies I can't even identify from their acronyms (and I'm pretty well versed in all things video). Otherwise, I wouldn't have just started a thread.
More color on the specific technicals around what I'm curious about:
I'm a film nerd and videophile, and I love my LG CX OLED, but 24p stutter (to be clear, the kind caused by the rapid GtG of OLED) drives me crazy. Almost as crazy as any shred of SOE, so motion interpolation, even on low settings, is essentially out of the question. I typically use BFI on 60- and 120- Hz material, but it's obviously only effective for that. Using 120-Hz BFI on 24p material doesn't seem to create any problems, but it also doesn't really help. IMO, that stands to reason, since the issue is only at the transition between different frames in 5:5 pulldown (i.e., where the cadence is A1, A2, A3, A4, A5, B1, B2, B3, B4, B5, C1, C2..., the transition between only A5 and B1, B5 and C1, and so on). It doesn't exactly help to strobe each individual frame at 120 Hz, and strobing at 60 Hz introduces artifacts due to the fact that it may strobe individual frames more than once and may not strobe between the 5th and 1st of each series of 5, etc.).
It always seemed to me like it should be feasible for a display, source device (such as a Blu Ray player) or a scaler (Like the Retrotink) to identify the 5:5 pulldown cadence and insert black frames specifically where they logically would help, at the end of the 5-Hz cycle of each frame: i.e., A1, A2, A3, X, X, B1, B2, B3, X, X.... It certainly seems like at least a 120 Hz display, seeing as it performs the 5:5 pulldown, would be able to substitute black frames for the last 1 or 2 of each 5-cycle sequence per frame. I'm wondering if there are any displays that actually do that effectively, or any other forms of hardware that accomplish or might be configured to accomplish that same objective. And to learn more about the science behind why.
Any input is much appreciated.
EDIT: Revised to fix typos and for clarity.
