Steam shader pre caching [CS2]
Riggedinho
Post by Riggedinho » 16 Jul 2024, 17:34
Hey guys,
I noticed that this option really worked and that there is a gain in FPS but above all FPS stability so the game is smoother, this is very noticeable for me.
Steam has changed its interface a lot in recent years with hidden options (few people in the community talk about it) and that's shaking up our old habits a bit :D especially when the game we're playing is much harder to optimize than CS: GO already was.
I strongly recommend that people who do not have super beefy PCs absolutely leave this option by default and therefore activated.
JimCarry
Re: Steam shader pre caching [CS2]
Post by JimCarry » 18 Jul 2024, 16:51
Hi mine was off now put in on and i think its better,what about the second option on or off ? (also yours is not in english i am gonna upload in egnlish)
Riggedinho
Post by Riggedinho » 18 Jul 2024, 17:34
Hi JimCarry
The second disable, only the first enable like by default
JimCarry
Post by JimCarry » 19 Jul 2024, 00:05
Riggedinho wrote:
18 Jul 2024, 17:34
Hi JimCarry
ok thanks,and no launch options right ?
Riggedinho
Post by Riggedinho » 19 Jul 2024, 03:44
@JimCarry
yes no launch option
JimCarry
Post by JimCarry » 19 Jul 2024, 17:41
Riggedinho wrote:
19 Jul 2024, 03:44
@JimCarry
except threads in my case is 5,this is the only one that gives fps.
The90sPope
Post by The90sPope » 21 Jul 2024, 12:46
Riggedinho wrote:
16 Jul 2024, 17:34
Hey guys,
I mean, this only works the first time you're in the map. Once you fully load it you don't need that Steam shader feature. I would not use it on CS2.
It's a waste of your resources for very little in return for a very short time.
“Death is a funny thing. Not funny haha, like a Woody Allen movie, but funny strange, like a Woody Allen marriage.”
― Norm Macdonald, Based on a True Story
Riggedinho
Post by Riggedinho » 23 Jul 2024, 13:19
@The90sPope
you are right, most definitely better to disable it.
JimCarry
Post by JimCarry » 23 Jul 2024, 22:14
so let's conclude,shader thing off,and only one lauch option ? (-threads)
Riggedinho
Post by Riggedinho » 23 Jul 2024, 22:19
Hi JimCarry
Yes shader disabled indeed I made an error of assessment.
As for launch options, I personally use none.
And then a lot of people have already said that putting launch options could be counterproductive. Back in the days of CS:GO a developer said he didn't recommend using the -high command.
As for the command you wrote I don't even dare to change anything as my game is perfect :D
