Benq xl2720z power button
Posted: 12 Sep 2014, 02:56
by ison
Hi guys
Just got my (2nd) benq from amazon.it (rev.2) --the 1st one had severe backlight bleed and i exchanged it-- and although the panel uniformity is better ...i spend about 15 minutes trying to power it up.
The touch button lighted up but the monitor wouldnt power on.
I had to actually search google and found this video that helped me power it on
http://www.youtube.com/watch?v=O0tso4IzMjY
Is this something normal and expected? I read in many review about the "problematic" touch buttons but this is frustrating at least.
Do you find it that difficult to use them or is my monitor faulty?
Re: Benq xl2720z power button
Posted: 14 Sep 2014, 15:51
The infrared button can be finicky, so make sure you have objects a little further away from the touch buttons, and add distance to any infrared-emitting sources (sun, incandescent desk lamp, Nintendo Wii bars, etc.)
Do a test:
- Cover up your window
- Turn off all lamps
- Now try to turn on your monitor, see what happens.
If the monitor powers up reliably, then try a process of elimination to find your problem source that's interfering.
Posted: 16 Sep 2014, 07:06
by n1catastrophe
I had the 24 inch version for a week or so before getting the 27 home. First thing I noticed was the power button WAS a bit more picky about how you touch it.
Use the bottom pad of your thumb. Similar to when you give a fingerprint. Not necessary to do the roll left and right technique. I put my four fingers behind the monitor so it wont rock a bit and just press with my pad. After trying it out a few times you will get exactly how to do it 100%.
