Solution: Go to NVIDIA Control Panel, Manage 3D Settings, Program Settings, find VALORANT, and set "Preferred Refresh Rate" to Application Controlled.
To be honest with you, I have no clue how I did not figure out this was the problem earlier. Something has always felt off however, and I can officially say everything that has felt wrong has been fixed.
This might not be the solution for you, but incase you're worried, open your monitor's OSD and find an option that will show the refresh rate on the top right. If it's correct, should display 240 for you.
