NVCP Ultra Low Latency Mode vs Max Frame Rate limit
Posted: 26 Jul 2024, 21:12
What are the best 'set it & forget it' NVIDIA Control Panel global settings for gaming on a 165Hz G-SYNC Compatible display? Specifically this is in regards to games where Low Latency Mode would be relevant (i.e. a game where NVIDIA Reflex is not supported). I've seen people make arguments for both of the configurations I've listed below and would very much appreciate a definitive answer.
G-SYNC: Enabled
Vertical Sync: On
Low Latency Mode: Ultra
Max Frame Rate: Off
--- or ---
G-SYNC: Enabled
Vertical Sync: On
Low Latency Mode: On
Max Frame Rate: 162 (-3 max refresh rate)
G-SYNC: Enabled
Vertical Sync: On
Max Frame Rate: Off
--- or ---
G-SYNC: Enabled
Vertical Sync: On
