Page 1 of 2
DPI appears to be incorrect
Posted: 29 Jul 2024, 22:01
by tryllix
I've tested more than 5 mice from different brands and it's the same thing. I have already changed the motherboard, video card, SSD, monitor, mouse, mousepad and keyboard and Internet Provider. I've already modified everything I could in Nvidia, Windows, BIOS, etc...
The problem is that the DPI seems slow, like it's not correct and I need to move the mouse more. Example: If I set it to 3000DPI it appears to be less than 1600, both on the desktop and in the game and it is not responsive at all.
I copied the sensitivity and general settings from some streamers that use a handheld camera and I need to move the mouse a lot, a lot more to get a 160°.
3080 EVGA ftw3
i9 10900K
Z590 Games
Re: DPI appears to be incorrect
Posted: 30 Jul 2024, 06:16
by RealNC
Did you recently switch to a 4K display from something like 1080p or 1440p? If yes, then what you're seeing is normal. Well, on the desktop and in games with non-raw mouse input, at least.
Posted: 30 Jul 2024, 15:15
by Slender
tryllix wrote: ↑29 Jul 2024, 22:01
3080 EVGA ftw3
i9 10900K
Z590 Games
what mouse? what monitor?
Posted: 30 Jul 2024, 22:22
by Tea
omg bro, I finally found someone with the same problem as me, please give me your contact information, discord, telegram or other, let's discuss
Posted: 30 Jul 2024, 23:09
by JimCarry
3080 EVGA ftw3
i9 10900K
Z590 Games
go in this site
https://www.mouse-sensitivity.com/dpianalyzer/
On Configured DPI type your dpi
On Target distance type 1
and then drag red crosshair on the blue crosshair precise as possible,and do a screen like mine.
Posted: 30 Jul 2024, 23:23
by Tea
JimCarry wrote: ↑30 Jul 2024, 23:09
3080 EVGA ftw3
i9 10900K
Z590 Games
go in this site
No, bro, I've known about this site for a long time, but you know, it's not very obvious to detect, it feels more like the mouse acceleration has been adjusted (btw, although I also turned on "Enhance pointer precision" before this problem appeared, so you can only feel it and the difference with normal mouse movement, but I'm sure one thing The mouse movement speed is definitely different from the normal movement speed
Posted: 31 Jul 2024, 10:59
by tryllix
Slender wrote: ↑30 Jul 2024, 15:15
3080 EVGA ftw3
i9 10900K
Z590 Games
My current mouse is the Deathadder v2, but I've tested other brands like HyperX and Logitech Superlight and they're both the same thing, the dpi doesn't seem correct. Never at 3000DPI should I move the mouse that much, it's crazy.
I only had 2 monitors, Acer Predator XB273GX FHD and currently the one I'm using, Alienware AW2521HF FHD.
Posted: 31 Jul 2024, 11:00
by tryllix
RealNC wrote: ↑30 Jul 2024, 06:16
No, I always used Full HD (1080P)
Posted: 31 Jul 2024, 11:07
by tryllix
Tea wrote: ↑30 Jul 2024, 22:22
Add me on discord:
tryllix1
Posted: 31 Jul 2024, 11:27
by tryllix
3080 EVGA ftw3
i9 10900K
Z590 Games
go in this site
3000DPI
400DPI
