Page 1 of 3
SEMI-FIX FOR INPUT DELAY
Posted: 13 Aug 2024, 15:04
by Jurr
Ive been having this issue on Xbox for 2+years now, sluggish movement, fighting my aim, delayed bullets on enemies allowing them to have more time to kill me even though they shouldve been dead.....
Also have input delay on my phone, these past 2 years it feels like Im faster than my phone especially when im typing, it doesnt register so i have to type like a grandpa to select the accurate letter. Scrolling is also delayed, its sluggish as fuck. Again, the same issue as typing i have to slow down in order to do what I wanna do. Ridiculous.
NOW, the semi-fix----- drumroll please 🄁🄁🄁🄁🄁🄁🄁🄁🄁🄁🄁
Air Purifier
I noticed that the sluggishness goes about ~80% away, still feels a little sluggish trying to track people and control recoil which makes me miss shots I shouldnt be missing. Another bad part is my bullets get absorbed by the enemy allowing them to get more shots off even though they should be dead blah blah blah, whatever right. Classic input delay issue we've all felt.
Like I said its a Semi-Fix if you want your game to feel more responsive and less sluggish, try it out. And ive tried everything, Air Purifiers actually remove static electricity, and it helps out with the game. If somebody that knows about electric work can look into this and come up with why this Air Purifier makes a difference, then we could get somewhere and tackle this issue.
Re: SEMI-FIX FOR INPUT DELAY
Posted: 13 Aug 2024, 16:49
by Slender
just use that on your pc case
Posted: 13 Aug 2024, 16:52
by Jurr
Slender wrote: ↑
13 Aug 2024, 16:49
why are u trolling? u arent funny
Posted: 13 Aug 2024, 16:54
by Slender
Jurr wrote: ↑
13 Aug 2024, 16:52
Slender wrote: ↑
13 Aug 2024, 16:49
you use an air purifier with a smell, why? You can use water in a spray bottle to spray it on the PC case, the effect is absolutely the same.
Posted: 13 Aug 2024, 16:56
by Jurr
what r u talking about
Posted: 13 Aug 2024, 16:59
by Jurr
Slender wrote: ↑
13 Aug 2024, 16:54
Jurr wrote: ↑
13 Aug 2024, 16:52
Slender wrote: ↑
13 Aug 2024, 16:49
The air purifier is removing something which is noticeably helping my game. We need to look into this and find out why that is. Do you wanna get to the bottom of this issue or not? Remember its not a PC exclusive issue. My Xbox, Phone are affected from this and the Air Purifier destroys about 80% of that sluggishness on both of my devices
by Slender
Jurr wrote: ↑
13 Aug 2024, 16:56
What I'm saying is that the water you use in the air purifier helps you remove interference from your PC, to do this more effectively and without harm to your health, I recommend that you use a spray bottle of water, which you should spray on the PC case. Just try this and then ask me what I mean, or are you completely stupid?
Posted: 13 Aug 2024, 17:50
by widow13
Slender wrote: ↑
13 Aug 2024, 16:59
Jurr wrote: ↑
13 Aug 2024, 16:56
He said purifier, the thing u are describing is a humidifier.
Purifier cleans the airs.
Posted: 13 Aug 2024, 17:57
by Tell
My guess is your air purifier has an ionizer and that is causing this. There's even a reddit post where their air purifier was causing a problem with their USB ports.
https://www.reddit.com/r/buildapc/comme ... e_for_new/
Posted: 13 Aug 2024, 19:00
by Jurr
Tell wrote: ↑
13 Aug 2024, 17:57
The Air Purifier is whats removing most of the delay for me. We need to dive more into this to find out why this is helping me
