Guaranteed desync/input lag fix
Lagsadok
If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
Then you may get 10 good min out of your pc.
Try it I promise it will work.
cursed-gamer
Re: Guaranteed desync/input lag fix
Sounds like madness but I can vouch there is some truth in it. When my sis played Valorant on my PC, she was top fragging like it was nothing for her. When I played 10 min on my brother's laptop in our house (where the issue for me exists) CS:GO was working really well. I always say this: all games work for me well ONLY IF IT'S NOT MY OWN PC/LAPTOP.Lagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
Lagsadok
Your last point is very correct, but try play for an hour or two, without failure the issues will be present. This exact thing I've experienced countless times.cursed-gamer wrote: β26 Aug 2024, 18:23Sounds like madness but I can vouch there is some truth in it. When my sis played Valorant on my PC, she was top fragging like it was nothing for her. When I played 10 min on my brother's laptop in our house (where the issue for me exists) CS:GO was working really well. I always say this: all games work for me well ONLY IF IT'S NOT MY OWN PC/LAPTOP.Lagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
My problems only started after moving from a rural area and moving to the city (issues about 4 months after moving), now even if I'm back in the countryside I have the same issues. Not sure if it has any relavance but just putting it out there incase someone else is in the same boat.
cursed-gamer
That is correct, in gaming cafe I needed around 30-45 minutes to see first symptoms.
In the Internet I found few more people with something similar but they are confused about what is going on, just like here:
https://www.tenforums.com/gaming/146343 ... -help.html
I'm not sure if it is about account (althought I believe CS2 is rigged piece of shit), because there was no account needed in Call of Duty 2 or Wolfenstein Enemy Territory. Also it happens in Valorant which is not connected with Steam. The guy is kinda confused so his last resort is blaming the account.[...]
First thing is when i was on NON-BYOC LAN's ( where u playing with LAN computer and can't bring your own ) my game was also super bad, choppy, delayed, hard to aim and etc. But when other people played on same PC (but with different account) their game was butter smooth no stutter no nothing. So i can make conclusion that this is not hardware problem but account. In lan it felt like im playing on 30hz monitor. In home 144hz monitor feels like im playing with 75hz.
Because in lan i played with my friend pc (lan computers same specs, same monitors), and he played with mine. And difference between my and his account was like day and night. I know one guy who have this same problem too (i found him in hltv). He trying to find fix 5 years in a row (like me) and still can't find a solution. he probably tried everything like me. BTW this is can't be Electricity or Internet problem. Problem somewhere else.............
BTW the issue stays with me for around 15 years. I came to the point where I'm gonna believe in everything.
internetexplorer4
did you test with less time? like 5 minutesLagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
also, what games did you play and how much it was fixed? like no problems at all or it was just better
when I tested with 2 people without the problem at the same pc, that didn't happen, they could use the same pc as me without any problems but as soon as I touch the pc, all the problems are instantly there, but we played for like 5-10 minutes and then switch, we did that couple times for testing, but not for 30 minutes like you did. I never had that experience of the problem caming back slowly tho
however, at my friends house, when I tried his pc, it was a lot better, not even close to a fix tho, this friend of mine has the same problem but way less than me, his interference is lower than mine, it felt like I played with his interference, I played for 2-3 hours on his pc and the feeling didn't change, it didn't get worse, but there is one thing, I did all those tests playing osu which is a offline game, so it can't have desync, I think desync might behave different compared to the other symtpoms like input lag and floaty mouse
maybe you had different results because you are experiencing mostly desync? or playing a game where desync affects a lot
if you can, try to test only the mouse precision in a offline aim trainer, it would be good
Patrykelele
are you fucking nuts idiot? iam done with reading supid dog postsLagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
cursed-gamer
What about your "ISP algorithms" unabling you to play? Have you find any evidence finally or still pushing your ass theories?Patrykelele wrote: β27 Aug 2024, 08:54are you fucking nuts idiot? iam done with reading supid dog postsLagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
f1ndus
I can confirm. I had same experience with this.
Patrykelele
ISP algorightms is something its writtine in my ISP TOS and propably in yourcursed-gamer wrote: β27 Aug 2024, 09:17What about your "ISP algorithms" unabling you to play? Have you find any evidence finally or still pushing your ass theories?Patrykelele wrote: β27 Aug 2024, 08:54are you fucking nuts idiot? iam done with reading supid dog postsLagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
cursed-gamer
I counted all my internet providers among the country especially for you. There were 10. What are the odds of having some "algorithms" on all of them while there are famous streamers in my city that I know for sure were using one of the worst providers available here and somehow reached 3300 elo on faceit?Patrykelele wrote: β27 Aug 2024, 14:53ISP algorightms is something its writtine in my ISP TOS and propably in yourcursed-gamer wrote: β27 Aug 2024, 09:17What about your "ISP algorithms" unabling you to play? Have you find any evidence finally or still pushing your ass theories?Patrykelele wrote: β27 Aug 2024, 08:54are you fucking nuts idiot? iam done with reading supid dog postsLagsadok wrote: β26 Aug 2024, 18:16If you have the issue where no matter what pc you use it will start having the same issue of input lag and desync, to fix it you will let someone else play your pc for 30 minutes, even your dad.
