[Unexpected cause] Mousepad, desk, skin, humidity
cursed-gamer
1. I removed my mat mousepad and played just on desk. I immediately noticed, that my mouse movement became super precise and I had to lower my sensitivity by 0.5 on 400 dpi. No more muddy feeling. Mouse pads are very good static generators because of vinyl and while you move your hand on it, it gets charged quickly.
2. Dry skin - creates good conditions for static build-up.
3. Low humidity - creates good conditions for static build-up.
4. Ground your desk, mousepad, chair. You can use clamps for better mounting.
Check it out by yourself
PS. Just one anegdote for you. I read somewhere that one console player had issue with his pad. It was going off or players in FIFA were doing some weird stuff randomly. He found out, that the cause of his problems was carpet. While playing he unconsciously scrubbed it with his feet and build up lots of static on his body. After removing carpet all his issues were gone. I buy it because this can be proven by physics instead of daily regedit windows fixes that do nothing.
Inputlagguy
Re: [Unexpected cause] Mousepad, desk, skin, humidity
Honestly u may be right about the static one way or another
Ive been noticing if i literally put the controller down for 5-10 seconds and pick it back up, i will have aim assist and can shoot straight for a clip or 2. After shooting longer than that it starts getting stiff and all symptoms come back.
This would also explain how i traveled far out of town and played on a friends set up and had the same problem. While im not there he plays completely fine absolutely no problems.
Could it be my clothing holding too much static? Lol like seriously do i not use enough dryer sheets?
cursed-gamer
Yes, don't wear polyester clothes, moisturize your hands, use plastic mouse pad and you will see the difference immediately. There may be much more static on your body than you think.Inputlagguy wrote: β05 Sep 2024, 15:44Honestly u may be right about the static one way or another
Patrykelele
Delete the post bro. Donk will see it and play without mousepad noone will stop him then.cursed-gamer wrote: β02 Sep 2024, 08:101. I removed my mat mousepad and played just on desk. I immediately noticed, that my mouse movement became super precise and I had to lower my sensitivity by 0.5 on 400 dpi. No more muddy feeling. Mouse pads are very good static generators because of vinyl and while you move your hand on it, it gets charged quickly.
cursed-gamer
Comedy geniusPatrykelele wrote: β05 Sep 2024, 16:47Delete the post bro. Donk will see it and play without mousepad noone will stop him then.cursed-gamer wrote: β02 Sep 2024, 08:101. I removed my mat mousepad and played just on desk. I immediately noticed, that my mouse movement became super precise and I had to lower my sensitivity by 0.5 on 400 dpi. No more muddy feeling. Mouse pads are very good static generators because of vinyl and while you move your hand on it, it gets charged quickly.
Patrykelele
commedy for commedycursed-gamer wrote: β05 Sep 2024, 16:58Comedy geniusPatrykelele wrote: β05 Sep 2024, 16:47Delete the post bro. Donk will see it and play without mousepad noone will stop him then.cursed-gamer wrote: β02 Sep 2024, 08:101. I removed my mat mousepad and played just on desk. I immediately noticed, that my mouse movement became super precise and I had to lower my sensitivity by 0.5 on 400 dpi. No more muddy feeling. Mouse pads are very good static generators because of vinyl and while you move your hand on it, it gets charged quickly.
cursed-gamer
If you are here to criticize everything around then just FO. You bring no value to this forum or any ideas.Patrykelele wrote: β06 Sep 2024, 15:16commedy for commedycursed-gamer wrote: β05 Sep 2024, 16:58Comedy geniusPatrykelele wrote: β05 Sep 2024, 16:47Delete the post bro. Donk will see it and play without mousepad noone will stop him then.cursed-gamer wrote: β02 Sep 2024, 08:101. I removed my mat mousepad and played just on desk. I immediately noticed, that my mouse movement became super precise and I had to lower my sensitivity by 0.5 on 400 dpi. No more muddy feeling. Mouse pads are very good static generators because of vinyl and while you move your hand on it, it gets charged quickly.
internetexplorer4
can you play this https://aiming.pro/quick-play (the hexakill one) with and without the changes to see if it really makes that difference?cursed-gamer wrote: β02 Sep 2024, 08:101. I removed my mat mousepad and played just on desk. I immediately noticed, that my mouse movement became super precise and I had to lower my sensitivity by 0.5 on 400 dpi. No more muddy feeling. Mouse pads are very good static generators because of vinyl and while you move your hand on it, it gets charged quickly.
or any other aim trainer/way to test, but I really would like some data or videos
me and others already tested these static related things, nothing worked so far, I tried electrical resistance gloves, anti-static gloves and anti-static wristband, I know people who tried grounding mat, and even playing while stepping on the grass. if the problem really is static, then at least one of these things should have worked
I'm one of the people who could confirm the problem is the body so I'm not trolling, but I do think that this could be a placebo or just a coincidence, if your results really show that this actually make a big difference, then we should investigate it more to know if it is really static or if it is another thing that changes something in our body or in the room/pc
- Slender
he's right, it's all checked by a tester for $20.
