Asus Rog Strix 24.5 XG259CMS
Hey guys this is my first post here. Building a new pc which meant upgrading my old monitor. I was on a AOC 144hz VA panel and I just ordered this monitor. Can't find many reviews anywhere. Was wondering if anyone knew the best settings for it? I play mostly competitve games like Valorant and such. The 310 hz caught my attention, but I know sometimes the overclock can cause more issues than benefits.
Re: Asus Rog Strix 24.5 XG259CMS
https://www.bilibili.com/video/BV1wU411S7tY/ @ 03:12 should be what interests you.gigapiga wrote: ↑07 Sep 2024, 20:51Hey guys this is my first post here. Building a new pc which meant upgrading my old monitor. I was on a AOC 144hz VA panel and I just ordered this monitor. Can't find many reviews anywhere. Was wondering if anyone knew the best settings for it? I play mostly competitve games like Valorant and such. The 310 hz caught my attention, but I know sometimes the overclock can cause more issues than benefits.
evaluating xhci controller performance | audio latency discussion thread | "Why is LatencyMon not desirable to objectively measure DPC/ISR driver performance" | AM4 / AM5 system tuning considerations | latency-oriented HW considerations | “xhci hand-off” setting considerations | #1 tip for electricity-related topics | ESPORTS: Latency Perception, Temporal Ventriloquism & Horizon of Simultaneity | good lcd backlight strobing implementation list
- synthMaelstrom
Just got this one a few days ago. Coming from an old VG279Q (2019 ips panel) this is a huge upgrade, so far I'm blown away by its ELMB sync which I was afraid would be some sort of a compromise, but I'm not seeing any downsides yet. There are a few quirks that I've noticed, however, namely if you try to change contrast or some other image setting while ELMB sync is active, there is flickering until you deactivate and reactivate the feature.
There is no way to control ELMB sync brightness through the menu, but I've found a workaround which I'm happy to share:
1. Configure the settings to your liking, then enable ELMB sync
2. Go to MyFavorite in the menu, save the settings as one of the two "customized settings" profiles.
3. Turn off ELMB sync
4. Go to customized settings and load the profile you've saved
Enjoy ELMB sync at a different brightness compared to the one the screen locks itself into if you simply toggle the feature through the Gaming menu.
As for the best competitive settings... I mainly play Apex Legends, and I've been experimenting with the following configuration, which is in no way a guideline, but here you go, in no particular order:
Gamevisual: User
ELMB Setup: ELMB-Sync enabled
Variable Overdrive: 16
Brightness: 50
Contrast: 80
Display Color Space: Wide Gamut
Color temp: 6500k
All saturation at the default 50
Gamma: 2.4 or 2.6
Shadow Boost: Level 3
What I've found is that the combination of dark gamma and high shadow boost kind of normalises the image without either eliminating deep blacks, oversaturating bright spots, or washing out the colours (snow on World's Edge doesn't blind you, and dark interiors are perfectly visible)
Now, to the one other quirk I've noticed with this monitor. Windows seems to have trouble rendering ClearType at 300hz and 310hz, because on a large number of websites including BlurBusters forums you get faint artifacts around some of the letters. Switching focus makes them invisible, so does using the Snipping tool, although once you begin snipping the area where artifacts are present, they only come back at certain sizes of the snip. Disabling ClearType eliminates them entirely. Weird stuff. UPD: setting ClearType to grayscale via BetterClearTypeTuner also eliminates the artifacting.
Gamevisual: User
Brightness: 50
Contrast: 80
Color temp: 6500k
Gamma: 2.4 or 2.6
Display: ASUS XG259CMS OS: Windows 11 Pro Case: Fractal Design Meshify C PSU: Fractal Design Ion+ 760p MB: ASUS X370 Crosshair Hero VI CPU: Ryzen 7 5700X3D w/Deepcool Assassin 4S GPU: Sapphire Pulse RX 6800 XT RAM: 4*8GB Patriot Viper Steel 3733MHz CL16 SSDs: 1TB Crucial P5 (OS), 3.5TB combined SATA SSDs Keyboards: Razer Tartarus Pro, Vortex Race III Mice: Xtrfy MZ1, Glorious Model I, Sound: ATH-M50X
I saw this monitor selling at 220$ but in EU is 350e...I want buy this but paying all that much for 1080p its crazy nowadays.
Should I just go for the 259qm instead?
- synthMaelstrom
I personally don't regret skipping the 259qm or 259qm1a for this one.
HI Synth, if i already have the vg259qm is a good idea sell it and buy the XG259CMS? here the cms is 120 dollars more than the 259qm.synthMaelstrom wrote: ↑16 Jan 2025, 05:42I personally don't regret skipping the 259qm or 259qm1a for this one.
Not a good idea, opt for 1,5x or 2x refresh rate upgrades or significant PPD upgrades (24" 1440p or better) at same or better refresh rate
Take a look at 360–480hz OLED, XL2566X+, XL2586x or upcoming new generation panels instead.
The new Q25G4S (24.5" 300Hz 1440p) is also a better option, at £239.
It's coming out in June 2025.
- synthMaelstrom
I agree with kyube here, it won't be much of an upgrade at all. If you're keen on trying out different panels for the fun of it, sure, sidegrade to your heart's content, but for an extra $120 it's not worth the hassle.kyube wrote: ↑09 Feb 2025, 19:22Not a good idea, opt for 1,5x or 2x refresh rate upgrades or significant PPD upgrades (24" 1440p or better) at same or better refresh rate
Gotcha, thanks guys, i think im gonna end buying the 380hz version of asus..xg259qns.. for 200 dollars more, dont like TN panels, in my country the aw2523hf is pretty cheap right know but i was reading that the alienware has ghosting problems and bad response times, oled is out of the question, 27 inches is too big for me.kyube wrote: ↑09 Feb 2025, 19:22Not a good idea, opt for 1,5x or 2x refresh rate upgrades or significant PPD upgrades (24" 1440p or better) at same or better refresh rate
All IPS ≥360hz have "bad" G2G response times compared to some TN's (e.g. XL2566K & newer BenQ E-TN's), some VA's (27G1S) or OLED (perfect G2G RT's for <1000Hz displays, therefore only “limited” by MPRT / refresh rate & processing delay)Doogydog wrote: ↑10 Feb 2025, 06:57Gotcha, thanks guys, i think im gonna end buying the 380hz version of asus..xg259qns.. for 200 dollars more, dont like TN panels, in my country the aw2523hf is pretty cheap right know but i was reading that the alienware has ghosting problems and bad response times, oled is out of the question, 27 inches is too big for me.
The XG259QNS won't be that much different compared to the AW2523HF in terms of response times.
