Page 1 of 2
ROG Swift OLED PG27AQDP 1440p 480Hz WOLED
Posted: 25 Sep 2024, 09:47
by Brutek_Vladimir
1440p 480Hz WOLED matte coating
Owner since 13.09.2024
Great for gaming (shocking right?), i come from benq xl2566k 360hz.
For desktop work not so much, despite being 2nd gen with new RGWB layout. Its better, but still not there.
If you know some tips for better readability of text in windows, im one ear.
Edit:
Monitor stand is one of worst i had, too much precious room on table is gone. Asus users will know. Use 3rd party stand imo.
Some bugs in OSD. Monitor "forget" power led is set to off after power out.
Some oled care settings turn back on after power cycle aswell.
Didnt made me a beast in comp gaming, but single player games are a lot more immersive for me.
1080p@360hz TN to 1440p@480hz OLED
My experience so far.
Re: ROG Swift OLED PG27AQDP 1440p 480Hz WOLED
Posted: 26 Sep 2024, 11:13
by Dalek
Brutek_Vladimir wrote: ↑
25 Sep 2024, 09:47
For this type of thread, be sure to post it in: 'General — Displays, Graphics & More' and not in News.
I was looking to purchase this monitor, but the reviews of desktop/text clarity seems to be mixed. Some people say it looks great, some people say it's not as clear as TN/IPS etc. I guess I'll wait until further progress is made.
Posted: 26 Sep 2024, 23:35
by Dalek
Also, if you put it to 24.5" mode, is the text clarity better or worse?
Posted: 27 Sep 2024, 01:52
by RealNC
25 Sep 2024, 09:47
Asus needs to seriously reconsider their stand designs. They are awful. They are cutting costs on them like no tomorrow.
Posted: 27 Sep 2024, 12:04
by Brutek_Vladimir
ah yes i see. i just decided to post new thread on whim after browsing
LG 27” 1440P 480Hz OLED CES 2024
@Chief Blur Buster
can someone move this to general lobby?
As for text clarity 24.5" mode doesnt matter OLED subpixel layout is culprit.
i cant post links, check tftcentral review there are pics
Posted: 27 Sep 2024, 12:28
by RealNC
27 Sep 2024, 12:04
Moved to OLED section.
Posted: 14 Oct 2024, 09:19
by Brutek_Vladimir
https://rog.asus.com/us/monitors/27-to- ... desk_bios/
New firmware: MCM103
Changelog:
Firmware Update - Bug Fixes and Improvements
• Modified DDC/CI Functionality and OSD Strings: Adjusted the Display Data Channel/Command Interface (DDC/CI) function and updated the On-Screen Display (OSD) text to enable the Display Widget Center to retrieve accurate data.
• Resolved ELMB Function Grayout and Mutual Exclusion Issues: Fixed issues where enabling Extreme Low Motion Blur (ELMB) caused other functions to be incorrectly grayed out or conflicted with each other.
• Corrected Abnormal Brightness Behavior with ELMB: Resolved abnormal brightness behavior that occurred when ELMB was enabled.
• Fixed OLED Anti-Flicker Mutual Exclusion Behavior: Addressed issues where turning the OLED Anti-Flicker function on or off caused improper mutual exclusion with other features.
• Updated OSD 'OLED Care' Menu Wording: Changed the wording in the OSD 'OLED Care' menu from "Local Dimming Control" to "Global Dimming Control" for improved clarity.
• Fixed Text Blurriness at 24.5-Inch Screen Ratio in Aspect Control: Resolved an issue where text appeared blurry when the screen ratio was set to 24.5 inches.
Posted: 18 Oct 2024, 08:38
by BTRY B 529th FA BN
Posted: 10 Nov 2024, 12:17
by StrobeMaster
14 Oct 2024, 09:19
I'd be hesitant with updating. According to this post over at RTINGS.com, MCM103 brings more regress than progress. Also the review at RTINGS.com is not exactly positive about this firmware (they ran their tests with MCM103):
RTINGS.com wrote:It has bugs that can negatively impact your gaming experience, as settings randomly change or don't work at all, so it may be worth waiting until these get fixed with a firmware update before buying the monitor.
Posted: 12 Nov 2024, 14:07
by Brutek_Vladimir
I updated to MCM103 via usb stick around 14. october and didnt experience these errors.
I dont use BFI/ulmb since XL2411T, because of eyestrain.
