Hello, I am a novice in terms of everything related to electricity, which is why I am asking my question here in order to have a little more visibility for my questions.
My question is: does this kit >
https://kitsolaire-discount.com/fr/kits ... ombination
Could support my needs regarding only my gaming PC with say 12+ hours per day on it.
For information, I am in the geographical area with the attached image.
The power supply is as follows > Corsair RM1000e (2023)
Thanks.
Using off-grid tips
akylen
Using off-grid tips
- Sans titre.png (113.29 KiB) Viewed 4002 times
delve
Re: Using off-grid tips
Don't do it, get a lithium power station instead that you can charge from the wall and return easily, if you want to test offgrid.
- solar only works 6 months a year
- who is going to install it safely and properly, not you
- lead acid batteries are trash
- likely not refundable
- solar off grid has been tested without success a bunch of times
- Slender
it is like big power bank?delve wrote: β11 Nov 2024, 21:47Don't do it, get a lithium power station instead that you can charge from the wall and return easily, if you want to test offgrid.
It can work with a 500W PC/monitor for so long?
Can charging this power bank from the bad elec. back the problem?
delve
you have to figure out the real power consumption of your pc, cpu + gpu TPD is a good rough measure plus the monitor of course. To power a 500W setup for an hour you would need a 600Wh power station for example.
spkii
Someone tried with this?
https://www.amazon.es/FOSSiBOT-F3600-Ge ... 84ed9b0efd
12 hours off grid, charged in 2 hours.
1nputlag
Hi akylen i saw you are french add me on discord: 0jsr
iizana
