Problem red spy always on when I turn on Gsync
Zazie
Post by Zazie » 13 Nov 2024, 11:46
I use gpu-palit-rtx-3050-6gb Kalmx and monitor Asus PG248Q (displayport).
With previous Palit gtx 1650 4 gb kalmx everything worked. I would turn gsync on from the panel, and the light at the bottom right of the monitor would only turn red when I was using gsync (I only use it in full screen).
Nothing changed. I only changed cards, no update except for drivers. I also installed the latest ones but the problem doesn't change.
Zazie
Re: Problem red spy already read when I turn on Gsync
Post by Zazie » 23 Dec 2024, 19:18
Help!
vlad54rus
Re: Problem red spy always on when I turn on Gsync
Post by vlad54rus » 23 Dec 2024, 20:28
Newer cards support Multiplane Overlays which allow G-Sync to natively function outside of fullscreen, this could be the reason.
Zazie
Post by Zazie » 25 Dec 2024, 15:56
Anyone has gpu-palit-rtx-3050-6gb Kalmx for comparison?
